Beat detective, canīt capture selection
I have a midi drum loop that was originally supposed to be played in 105 BPM, and I want to use beat detective in order to tighten things up a little.
The problem is now that when I select an area covering 4 bars, and then press "capture selection", and then press "generate", I get a message saying "bar/beat markers can not be generated in manual tempo mode". As I understand it, the way to activate and de activate manual tempo mode, is by pressing the conductor symbol, so I try that, but then the tempo automatically goes to 120 BMP. How can I keep the tempo to 105 BMP and still be "auto mode"? Or, I am doing it wrong by pressing the conductor symbol when trying to get out of manual mode, is there any other way to do it? |
Re: Beat detective, canīt capture selection
Easiest way is to go to view>rulers and make sure tempo is switched on. Now click the conductor off (you are doing that right). You should see when you do that the song start marker - the red diamond in the ruler - has the tempo 120 appear next to it. Double-click on the diamond and enter your new tempo of 105. Done!
PS - any tracks set in tick ref will move when turn the conductor off, but don't worry they should all move back when you set the tempo back to 105. |
Thank you! |
Beat Detective Capture selection error | Stay Where I Can | macOS | 0 | 07-25-2012 12:29 PM |
Beat Detective - Capture Selection | thin ice | Pro Tools TDM Systems (Mac) | 27 | 02-07-2011 08:16 AM |
> Beat Detective Bug PT 8 - conform long capture | Howardk | Pro Tools TDM Systems (Mac) | 28 | 07-10-2010 08:57 AM |
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! | Robbry | Pro Tools M-Powered (Win) | 0 | 02-24-2010 02:14 PM |
Beat Detective Help: Capture Selection | AtomicBeagle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-19-2009 05:27 PM |
