Stereo in only on left channel
I just hoked up the D-Command today and played arroud for about 2 hours, testing all the routing. I have stereo 1 for CD Stereo 2 for DigiBeta and stero 3 for Tuner. as I tested the signal I had signal on all inputs left and right. I might have done some weird setup, but suddenly I have only the left channel on all 3 Stereo in with signal, The right is dead. I have powercycled the system, reset the D-Command to default reloaded the firmware in the Xmon and replaced the snake. nothing works. BTW the main (protools) is fine in stereo L/R. Can anybody help?
Re: Stereo in only on left channel
The D-Command meters monitor Stereo Inputs in the following order : L-Lc-C-Rc-R-Ls-Rs-LFE so the meters on the D-Command show L on 1 and R on 5. Does this shed any light?
To further clarify, coming out of the Xmon, left is on 1 and right is on 5.
If you connect your interface to the Xmon via 8 channel D-sub cables, you can change your IO setup so that your main monitoring outs from PT come out 1-5 instead of 1-2. You would then need to feed your monitoring from 1-5 out from the Xmon. If you only ever want to use the Xmon in stereo, then you could get some Dsub to XLR breakouts and connect 1-2 out from the interface to 1-5 in on the Xmon and then monitor on 1-5 out from the Xmon. Both of these scenarios allow for stereo in monitoring via 1-5 out from the Xmon.
I'm confused. I understand the 1-5 routing for the main ins and outs of the xmon, but the Stereo Input channels are are 1-2, 3-4, 5-6 according to all documentation I've seen...
Patching sources into these inputs gives me level on the meters for 1 and 5, but no audio on the right side... What am I missing? Thanks! -Zak |
Thanks Craig,
Just figured it out...turns out I have been looking at VERY old documentation and the pinouts have apparently changed since then. Repatched and...voila! Happy camper now. -Z- |
Hi badbiker, did you ever figure out what caused this? I know this is an old post, but I'm having the same problem. I've checked all my cabling, reset all firmwares and even changed out with a different xmon and dcommand...I'm at a total loss. Any help would be greatly appreciated, thanks in advance!
Oh, I've had the same issue, starting a couple of weeks ago. Proper cabling, correct routing. Out of a sudden, there was no signal on the right channel - sometimes just on the main, sometimes on one of the stereo sources. Since a few days, XMON started to mute all the channels and fails. And since yesterday, the unit is completely dead. Even the firmware update procedure will be quitted by an error 1 or 2 message. This is my 2nd XMON in 5 years. Not to speak about the 3rd D-Command in the same time. Oh - and on the 3rd D-Command, I had to change all the faders recently. And some of the pan knobs still don't work. Did I forget to talk about a nice «scratch» besides the EQ section? It was there from the beginning. Documation pictures and many mails didn't help DIGI/AVID to move their asses and get that fixed or exchanged until now. What a shame. Otherwise, the console works fine...
Left Channel Audio Regions on Timeline force to Original Stereo | leobaker | Pro Tools 10 | 2 | 11-10-2013 10:41 AM |
Stereo Aux Track only receiving left channel | DRI | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-26-2011 10:59 AM |
Strange CoreAudio issue - right channel information getting into left channel | -JK- | Pro Tools 9 | 5 | 01-10-2011 08:42 AM |
Stereo Track Help Please - Pnly Getting Left Channel | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-06-2007 10:38 AM |
fix for left channel | Jeff Hodges | ProControl, Control|24, Command|8 | 8 | 05-05-2002 04:51 AM |
