Old 12-05-2006, 12:22 PM
WStarnes WStarnes is offline
Default Using Beat Detective with Tempo Changes
I was hoping some users could offer some tips here. I am trying to use Beat Detective on some drums and percussion tracks and having some odd results. The session that I am working on has various Tempo Changes throughout. Very slight tempo changes, but changes nonetheless.
In using Beat Detective, in the normal way, I like to work on smaller 8 bar regions at a time to get better results. On this session (and sometimes others), I keep getting weird results, where clicking Region Conform is creating erratic odd movements. I believe this is cause by Tempo Changes. In the PDF manual, under the chapter: "Defining A Beat Detective Selection" it states that the "The Selection should not contain any Tempo Changes or Meter Changes"
Although I am very shocked to read that Beat Detective can't work over sections with Tempo Changes, I have done this in the past, although it took some trying and re-trying to get things working.
What is happening today is:
-Select an 8 Bar area on a region, say Bars 8-16 to use Beat Detective.
-Use normal steps (Capture selection-Analyze-Separate-Conform)
The oddity is that even though my Capture selection was only Bars 8-16, sometimes hitting Region Conform will make odd cuts and movements down at bar 29,30,31 for example. (I didn't even select a selection down that far yet!)
In looking carefully, those other bars (29,30,31)are indeed where some Tempo Changes occur. So that brings me back to the original question:
Is the manual indeed 100% correct, that you can't use Beat Detective across parts of a song with Tempo Changes? (bummer if so!) and Secondly:
If that is the case, does anybody have a workaround or tip to use BD in a song with Tempo Changes?
Thanks for any tips,
Wade
Tempo mapping Beat Detective or identify beat? grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2012 10:13 PM
beat detective and tempo kevinsimons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-26-2009 05:57 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 02:31 PM
Beat Detective TEMPO PROBLEMS! HELP! RightOnRecording Tips & Tricks 0 03-15-2005 01:26 PM
Beat Detective/Tempo Changes jeff...ya know...jeff Tips & Tricks 3 01-22-2003 07:31 PM
