Old 08-30-2010, 10:57 PM
michaelm michaelm is offline
Default track height changes unpredictably
all of a sudden (or after something I did I'm not aware of ...), when I select a track or just click in it, it reduces its track height (while the track above it increases in height)
this is driving me crazy (every time I want to edit a track it first gets smaller, then I have to enlarge it, etc.)
it's not a general occurrence - it only happens with one particular project, other projects behave normally
any ideas why this is happening? thanks for any enlightenment!
after more research: the playback is also affected somehow - it will not play back from where I click the cursor, but only from its last position
I have checked project backup files - and all this happened after I imported an audio track recorded by someone else on another computer (a Mac, but this has never caused problems, I have imported many of his files for this project) - there must be some property imbedded in this track that changes some settings - can they be seen somewhere? changed? ignored?
Pro Tools 8.03, Fujitsu-Siemens AMILO Xi3650 laptop, 18.4 in. HD display, Intel Centrino2 Duo CPU P7350 @ 2.00GHz, NVIDIA GeForce 9600M GT graphics, Realtek High Definition Audio, 4GB RAM, Vista HP (32-bit), Digidesign Mbox 2 Micro
Old 08-30-2010, 11:23 PM
mano111 mano111 is offline
Default Re: track height changes unpredictably
Think its called track focus - press E (toggle) or there is a button right under the editing tools.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 08-30-2010, 11:38 PM
yes! thanks! that was it - how simple
but I am wondering - is this something that an imported track could change? or did I just hit the E key by mistake?
by the way, nowhere in the manual seems there to be a reference to this (keyboard focus yes, but no track focus)
Old 08-31-2010, 05:20 PM
The Weed's Avatar
The Weed The Weed is offline
IIRC look for Zoom Toggle.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-31-2010, 11:01 PM
indeed, there it is, if only one knew sometimes what to look for .....
thanks
Old 09-01-2010, 05:55 PM
The Weed's Avatar
My pleasure.
Cheers,
SonoBus
track height jknourse Windows 1 07-18-2012 02:06 PM
How to LOCK a Track Height? teacherman Tips & Tricks 3 04-29-2010 06:31 PM
Track height problems in PT 7.1 fuzzles Pro Tools TDM Systems (Mac) 8 09-20-2008 11:34 AM
Track Height Weirdness Media Man Pro Tools TDM Systems (Mac) 3 04-02-2008 12:53 PM
Group Track Height won go away!!!! mstucker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-08-2007 02:46 PM
