HDX cards in Netstor NA211A-G3 expansion box?
I was wondering if there some folks here that are using Netstor NA211A-G3 PCIe expansion box with HDX cards inside? I was looking into putting HDX2 inside.
Re: HDX cards in Netstor NA211A-G3 expansion box?
I’m using the previous generation NA211A with PCIe 2.0 slots and HDX3. Works great.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
That is good news, all tree cards in de box? And you could also convert this box to thunderbolt, in the future.
Yes, when I bought it, they said the PCIe connection card could be swapped out for TB some day.
All three HDX cards are in that one box. Actually, I’m using a totally of two Netstor PCIe expansions on the same system. The second one houses a usb 3 card, PCIe SSD for the system drive, and a SAS Raif card the runs separate SSD raids for project files and video playback.
And everything works as expected, no troubles so far?
I am looking into buying the G3 version and KIT as well to turn this one if necessary onto TB3! |
No problems at all. I’m using them with a 2012 MacPro tower. 10.12.6. And always the latest PT version. Everything is rock solid.
By the way, I did get the ‘GPU’ version with bigger power supplyTo make sure all three HD X cards had enough power. But it looks like the PCI version 3 that you want to buy already has the bigger power supply. So this is more just a warning for anyone reading this who buys the older PCI version to like mine, you should get that larger power supply in the GPU version.
Expansion Cards on I/O | jre3132 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-25-2016 08:17 AM |
HD i/o AD and DA expansion cards | gsharp | Buy & Sell | 0 | 12-29-2013 11:24 AM |
192 I/O Expansion Cards | egghead | Pro Tools TDM Systems (Mac) | 2 | 11-11-2011 12:21 PM |
192 Expansion Cards | Martin Adriaanse | Pro Tools TDM Systems (Mac) | 6 | 02-07-2005 03:56 PM |
192 Stock I/O cards used as expansion cards? | barthalamu | Pro Tools TDM Systems (Mac) | 2 | 02-03-2004 12:00 PM |
