Old 06-10-2023, 03:49 PM
HearInc HearInc is offline
Default PT 2023.6 broke Avid Control app on iPad
The app says it's connected in the Settings/About on the app, but no faders show up, transport doesn't work, etc.
I opened an older version of PT as well as Logic Pro, both work as expected.
Am I missing a setting or something, or is it actually broken?
Brian Steckler, Producer
Old 06-10-2023, 04:32 PM
Ben Jenssen's Avatar
Default Re: PT 2023.6 broke Avid Control app on iPad
I'm running PT23.6 too, and Control is working fine on my iPad. I read somewhere on the DUC recently about people with problems like this actually rolled back one version of Eucontrol and it fixed the problem. So I haven't updated Eucontrol on the mac - I have v 2022.12.01.
Old 06-10-2023, 04:34 PM
I'll give it a try. Thanks Ben.
Old 06-10-2023, 05:21 PM
No luck... tried the last 3 versions of Eucontrol... nothing works. Not sure how to roll back the iPad app...
Old 06-10-2023, 05:32 PM
Too bad.
I didn't update the iPad app. I don't think there even is an update, since last year.
And I don't think installing earlier versions of iOS apps is even possible.
I think you should perhaps give a little more info; like does the ipad show up in 'surfaces', what have you tried for troubleshooting etc, and let's hope someone can help
Old 06-10-2023, 05:35 PM
carlone carlone is offline
Same problem here - after updating to 2023.6 my S1 wouldn't bank. After trying multiple things I held shift and clicked one of the user button and that did it. Not sure why but it's working.
Old 06-10-2023, 05:37 PM
Everything works fine in 2023.3.
With 2023.6 the iPad shows up fine in EuControl settings, and on the app it shows that it's connected. But, nothing shows up.
I've tried multiple versions of EuControl, back to 2022.9 (which won't connect to this version of the iPad app (2022.12.1.153).
Not sure what else to try.
Old 06-12-2023, 10:57 AM
OK, so, I've tracked the issue down to Native/Rosetta.
Everything works, including 2023.6 if it's running Natively. Turn on Rosetta and I lose the iPad.
Hopefully Avid can fix this because there are still plug-ins I need from time to time that won't run Natively yet.
Old 06-12-2023, 11:02 AM
Interestingly, this holds true for Logic Pro as well. Open with Rosetta, EuCon breaks.
Old 06-12-2023, 01:30 PM
its2loud its2loud is offline
Folks. If you're running 2023.6 under Rosetta then you need to enable Eucon the old way. Peripherals/Ethernet Controllers. Check the box for EUCON Control Surface.
See the pic.
File Type: jpg Screen Shot 2023-06-12 at 1.28.30 PM.jpg (27.8 KB, 0 views)
Pro Tools / Avid Control App / iPad (8th Gen) Zergei72 Avid S1, S3, Dock and Control App 8 08-01-2022 12:52 PM
Avid control for ipad tonyw7 Avid S1, S3, Dock and Control App 2 01-03-2022 08:26 PM
Does PT First support Avid Control iPad app? atkeyboards Pro Tools | Intro Discussion 4 02-13-2021 03:17 PM
S3 + iPad Running Avid Control priorytools Avid S1, S3, Dock and Control App 0 06-07-2020 05:13 AM
New Avid Pro Tools Control for iPad nst7 Avid S1, S3, Dock and Control App 261 10-13-2015 12:33 PM
