Protools 10 and Windows 8, 64 bit
Hey I just bought a new pc which is 64 bit. Is Protools 10 compatible with Windows 8, 64 bit
Re: Protools 10 and Windows 8, 64 bit
So I should just try to install it and see what happens?
I have been running Pro Tools 10 on win 8 64bit since it came out. And windows 7 64bit before that. It runs the same for me. Actually better in windows 8. Where it would freeze during bounce on 7 no longer happens on 8. So that was a plus for me. There are a ton of threads regarding windows 8 and PT 10. I'm happy with it.
And the 64bit part doesn't make a difference. If you have over 4 gigs of memory pro tools will have access to the full 4 gigs, instead if sharing memory with the system. Sent from my iPhone using Tapatalk - now Free |
A lot of variables here...does the "new PC" meet the compatibility requirements? (As one of my engineers at the college always says, Pro Tools is a DIVA.) Does it have a secondary hard drive you can dedicate as a recording drive? Also, if memory serves (which fails me occasionally) didn't AVID state that PT 11 was in fact Win 8 compatible? |
Well my pc is an i7 quad core with turbo boost up to 3.9ghz, 8 gigs of ram and 1 TB hd with 32 gb SSD. Do you think that is ok?
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Pro Tools 11 (not HD) is the only version officially qualified by Avid for Windows 8.
There are several, including myself, that do run Pro Tools 10 (also 10HD and 11HD) on Windows 8. I actually had Pro Tools 9 running on Windows 8 and I even got PT LE8 to run on Win8 just as a test, and they all worked That's worked, NOT approved. In general, if something works on Windows 7, it should work on Windows 8. Keep in mind if you have trouble, the first thing that will be suggest by Avid if you call them up is to run a qualified, tested system. So you will be on your own officially for troubleshooting.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
How do you post a Sandra report
Probably, but you still need that secondary hard drive if you want it to work reliably. |
Protools 6.4 and Windows 7 | loginame | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-25-2014 11:01 PM |
Windows ProTools 10 freezes at the click of "Install ProTools 10" | JakeStrauss | Windows | 1 | 10-01-2012 08:53 PM |
Running Mac ProTools files on Windows ProTools | DJ_Invisible_Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-16-2009 04:07 PM |
convert Mac protools 7.0 to windows protools 6.4? | Strainj1 | Pro Tools TDM Systems (Win) | 1 | 11-07-2006 10:42 AM |
Will Protools 5.1 run on Windows XP pro? HELP!! | Brian Maxwell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-27-2003 02:12 PM |
