Old 03-15-2011, 05:07 PM
melvinR melvinR is offline
Wink Calibration
Hi all
I'm trying to calibrate my pro tools HD, and thinking about the Behringer CT-100 cable tester that has tone generator on 1khz. Has anyone having any problems with this unit in terms of the level wise that coming out of this unit? any some suggestion effective way to calibrate my 192 unit.
Thanks
melvinR.
Old 03-15-2011, 11:24 PM
BillDog793 BillDog793 is offline
Default Re: Calibration
Hey, I have that cable tester and love it. Never used the signal generator to calibrate though. Here's a link though that might offer some help.
http://www.audiorents.com/library/so...ode_192_IO.pdf
Old 03-16-2011, 12:37 AM
How would you calibrate the input if the output of 192 it self not calibrated or different value from i wanted, do we need external signal generator ?
Old 03-16-2011, 05:45 AM
Hamdi Hamdi is offline
Any @ DUC know where to find calibrating 192 on youtube.
Thanks.
Old 03-16-2011, 10:13 AM
1st calibrate the outputs using the 'signal generator' plug in with outputs feeding a DVM or calibrated VU meter - typically you'd want a -18dBFS sine wave feeding a mono output to measure 0VU = +4dBu on an RMS-capable DVM - then feed the calibrated output to the input channels to cal the inputs.
best,
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 03-16-2011, 11:20 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Make sure your tone generator is at the correct level or you are wasting your time. As recommended, use a DVM or scope to make sure the level is correct.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 03-16-2011, 03:09 PM
That's what i'm afraid off.
Old 03-16-2011, 03:22 PM
I think this is helpful, thanks guys for helping me.
http://www.dynamicinterference.com/2...r-io/#more-382
Old 03-17-2011, 03:07 AM
Darney Darney is offline
Hi all
Thanks
melvinR.
The CT-100 is a clone of Ebtech's Swizz Army Knife (I have one). While it's one of the most useful tools you can have as a sound tech or engineer, the test tones (400 Hz and 1KHz) may not be accurately calibrated in terms of frequency or level. For checking a signal path or cables, it's great, however, I wouldn't use it for system calibration.
“What fresh hell is this?” - Dorothy S. Parker
Old 03-17-2011, 03:41 AM
Can I use my old TEAC Model TO-122A Test Tone Oscillator to
calibrate my 192 i/o?
Thanks.
[IMG] code is Off
Calibration how to? Terry Wetzel General Discussion 8 08-03-2015 05:02 PM
c/24 and 192 io calibration raga2000 Pro Tools TDM Systems (Win) 0 07-24-2007 04:00 PM
What are you using for Calibration?? SHIRK Pro Tools TDM Systems (Mac) 4 02-23-2003 01:26 AM
calibration joestudio ICON & C|24 0 04-27-2002 08:32 PM
Calibration JLEpperson Pro Tools TDM Systems (Mac) 3 08-08-2001 11:07 AM
