How do you get the right volume when mastering?
When mastering, keeping to below the red is too quiet, so I up the volume by a few db. However I find that listening for audible distortion is alot more difficult and time consuming than seeing if peaks hit a graphical level. So is there any way of viewing volume levels to check for distortion?
Dan |
Re: How do you get the right volume when mastering?
an occasional dip in the red isnt that bad. Protools has some headroom build in.
Alternitavly you could throw for example a digirack compressor on the masterfader and set it to bypass. It will give you a bigger meter Bastiaan
What's that? - That's the machine that goes "pling". Bastiaan |
I already put a compressor on it to get the larger meter, but the compressor goes into the red as well - as expected - and doesnt distort untill it is way into the red. So is there no other way of viewing when distortion will occur?
Dan |
Do you have a dat-recorder? Or anything else you can connect to the digital output of the digi (or AMIII) i think that will give you a good reading. The professional RTW-meters would be great too, but wayyyyyy to expensive......
Bastiaan
You may try putting a limiter at the end of your processing chain set at -2db.
Chris Thom ChrisThom.net Time flies like the wind; Fruit flies like bananas. ~ Groucho Marx |
Waves L1+UltraMaximizer as the last plug on my Master Fader, using the 'Mastering' preset, whatever that's called I can't remember, but you'll find it immediately in the list of preset options. It sets the output to -0.2dB, I think, and I don't think I've ever seen a clip on the output when using this plug in. Mark |
Thanks guys. Much appreciated.
Dan |
Volume for Mastering. | KNM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-01-2010 04:34 PM |
Volume in regards to mastering | Matt Subbz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-06-2010 02:22 PM |
Mastering/Maximum volume | sunnyside | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2008 04:38 PM |
Mastering: Commercial Volume | nero120 | Tips & Tricks | 16 | 01-23-2007 09:51 AM |
Mastering volume | chaplain64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-04-2005 06:33 AM |
