PT 7.4.2 does not lauch
I updated to PT 7.4.2 but when I try to start a session the program begins to load plug-ins. On this stage the program get stock on either DigiRewire.dpm or Chorus.dpm plugin.
Please any clue on how to fix this. Thanks |
Re: PT 7.4.2 does not lauch
2.4 GHz Intel Core2 Duo 2 Gb 667 MHz DDR2 SDRAM |
Plugins up to date?
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers |
Did a search and found this:
Pro Tools freezes on DigiRewire.dpm when starting the program on a Macintosh with Mac OS 10.5.x Leopard. If Pro Tools freezes on DigiRewire.dpm when starting the program, this is usually due to an incompatible version of Melodyne Essential being installed on the system. The version of Melodyne Essential on the Ignition Pack 2 discs is 1.5.1, which is incompatible with Mac OS 10.5.x Leopard. To fix the problem, follow these steps: 1) Quit all running programs 2) Open the computer's startup drive (commonly named "MacHD") and navigate to the "Library" folder, then to the "Application Support" folder, then the "Propellerhead Software" folder, and finally the "ReWire" folder 3) In the "ReWire" folder, two files need to be moved to the trash. These are "MelodyneEssentialRewireDevice" and "MelodyneEssentialRewireDevice.plugin" 4) Pro Tools should now launch properly If you have the original Ignition Pack installed, you may experience the same issue, but the fix is a little bit different: 1) Quit all running programs 2) Open the computer's startup drive (commonly named "MacHD") and navigate to the "Library" folder, then to the "Application Support" folder 3) In the "Application Support" folder delete the "Propellerhead Software" folder, "ReWire", "REX Shared Library", and "MelodyneEssentialRewireDevice" 4) Pro Tools should now launch properly
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Obsidian Dragon
thanks, I will try it. |
unable to lauch Pro Tools LE | polipeen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-11-2008 04:23 PM |
digi 001 wont lauch protools 6.4 | fatality2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-26-2007 08:06 PM |
LE 6.9.2cs won't lauch (Mac OS 10.4.2) | David Penick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-06-2005 05:04 PM |
Freezes when trying to lauch DAE ??? | vudoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-07-2001 01:33 PM |
pt free won't lauch | satxguitar | Digidesign Hardware & Software | 4 | 03-29-2001 11:41 PM |
