Old 11-26-2023, 07:57 AM
Hellrow Hellrow is offline
Default Move midi without affect BPM
Hi!
I got a question.
When Im in writing mode I always makes alot of songs in the same project to save time. When I start to mix I use to save a project on each song.
If I got for an example 5 song in a project its probably in 5 different tempos.
When I go to mix, my wishes is to for an example lay my no3 song in the project on Bar nr 1 int the mix project but if I got different tempos before that song in the main project everything flips.
Old 11-26-2023, 08:59 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Move midi without affect BPM
Hi, I'm not sure I totally understand the example, but it sounds like you would want to set the MIDI track to work in Samples (opposed to Ticks), and Cut the bars leading up to the song you want to use in the individual session. Setting it to work in Samples will not move the MIDI notes in one song to adapt or adjust to a different tempo.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-26-2023, 09:48 AM
Hi thanks for your answer.
My midi tacks was in sample but I solved it in another way that I didint had tried.
Thanks!
Groovecell: Midi cc should affect focused pad!! Dennisf Virtual Instruments 0 09-17-2022 08:17 PM
Would move into trash affect audio quality? Rockman413 Pro Tools 12 17 10-27-2017 06:23 PM
Fader on a MIDI Track in PT12 doesn't affect instrument volume while adjusting it composer8million Pro Tools 12 49 11-09-2016 05:39 AM
How does disc cache affect a session full of midi/VIs? DontLetMeDrown Pro Tools 10 2 02-26-2012 10:02 AM
Can't move midi notes Dopamine Pro Tools TDM Systems (Mac) 4 10-10-2002 03:32 AM
