Old 11-18-2023, 09:08 AM
Treblecorp Treblecorp is offline
Default Not able to record with
Mac Studio M1
ProTools Artist
Volt 2
AT 4040 Cardoid Capacitor Microphone
There probably is a really simple fix - it is just not coming to me right now
I plug mic into volt 2, input 2 and choose the same input under I/O for that track. I also activate 48V phantom power on Volt 2. I can hear the signal coming through volt 2 but only on the right side, (even though the track is panned in the centre) as to why it only comes out of right monitor
I engage the record feature top right as well as on the track.
I am not getting any signal level on that track and as a result I am not able to record.
Any ideas of what I should check? I have reset input/output to default, thinking it would work - nothing changed
Old 11-18-2023, 11:10 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Not able to record with
What do your I/O settings look like in Settings and on the track? Do you have LLM enabled?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-18-2023, 12:25 PM
Expanding on Chris' questions/suggestions
Having Low Latency Monitoring (LLM) enabled is a frequent cause of just not hearing monitoring signals when recording since it disables software monitoring though Pro Tools.... tracks with live physical inputs and physical outputs will have their outputs muted (but stuff is still recorded to the track). LLM is intended for when you are hardware monitoring and just want to get Pro Tools software monitoring out of the picture. However if no signal is appearing in Pro Tools (no track meter movement, no waveform on the track), this is not the problem.
Make sure you are trying to record to an Audio track, and in this case a mono audio track. It's very common for new users say to try to record to an instrument track if for example they are might be recording an acoustic guitar with a mic. If it's an instrument track you won't see meters move or wave forms recorded... and if you look close you'll see the track uses piano key UI elements meaning it's meant to record MIDI not audio. And all of us have fat fingered create track at some time and tried to do stuff with the wrong track type.
I'm assuming you can playback recorded audio OK. If not sure drag a known good audio recording to the Pro Tools Edit window and let Pro Tools create a track for that and make sure that plays back OK.
The playback engine is the Volt 2 itself? Right? It's not part of an aggregate device?
I suspect you are hearing hardware monitoring through the Volt 2. It has two hardware monitoring modes that will either mix the mic inputs to stereo or leave them mono in the L/R outputs. You should read the Volt 2 documentation.
You need to work out if you want to hardware monitoring (engage the correct hardware monitoring mode on the Volt2 and enable LLM in Pro Tools) or software monitor (disable hardware monitoring on the Vol2 and uncheck LLM in Pro Tools).
"Low Latency Monitoring" is not a great name for this it should just be called "Disable Software Monitoring" but it is what it is for historical reasons.
The "record feature" is called "track record arm" or just "arm". The thing top right is the "record button" and it's part of the transport controls, which you can have up in the edit window toolbar or have as a free floating window. You too can join the rest of us faking we know what we are talking about.
[QUOTE]
[QUOTE]
Meaning exactly what?... You don't see the Pro Tools track meter move and/or any waveform being recorded to the track??? You are vertically zoomed into the track enough? And the preamp gain knob on the Volt 2 is turned up sufficiently.
While tracking (recording) your tracks should be in pre-fader meter mode (Options>Pre-Fader Metering). Make sure that is correctly set.
[QUOTE]
That's a very good thing to do when troubleshooting. BTW when you do this you also likely want to also default busses. And be careful and double check that the correct interface is selected as the Playback Engine before you do this (Pro Tools can sneak up on you and select the wrong interface when you least expect it).
Old 11-18-2023, 02:33 PM
Thanks for all these comments, much appreciated and I will read through everything. Still figuring out the terminology.
Two things I know for sure is that,
one, I am using audio tracks. I have been diving deep into protools, for the past 12 months, mostly recording direct with guitar, using loops and MIDI. This is the first time I am using a microphone, and I know the difference. And I checked that as well, even creating a new audio track. Just to be sure, I will open a song I know works and then check to see if I can record with the mic
And
two, low latency is unchecked.
What I meant by no signal (probably poor choice of words) is that I am not able to record, even when the track arm feature and record button are enabled and I/O is set to the correct input.
You suggested a few other things. I will try that and let you know how it goes
Old 11-18-2023, 02:59 PM
So especially watch the track level meter in Pro Tools and the waveform and describe what they are doing. I'd set it to classic meter type (in Setup>Preferences>Metering) just to be sure and maybe default all the values in case you have messed with them... and make sure you are it is in pre-fader metering mode. That way you see the signal level going from the interface to disk on that track.
And backing up a bit. Since this is the first time using a mic... What exact connection do you between the Mic cable and Volt 2. It needs to be an XLR connector connecting to the Volt 2 combo plug input (it would be a bit of a mystery why this worked in mono during recording if this was connected to the line level TRS input).
Old 11-18-2023, 03:26 PM
Thanks, it is XLR - I will check metering now. I also reviewed the Volt 2 documentation and know why I was only getting sound out of monitor - that is resolved.
Thanks again,
One other thing, I don't see the AT4040 microphone showing up on the input list. Is it supposed to be there?
Old 11-18-2023, 03:34 PM
How do upload an attachment? I am not seeing a way to set metering to default settings. And want to upload screen shot
Old 11-18-2023, 03:40 PM
sw rec sw rec is offline
“One other thing, I don't see the AT4040 microphone showing up on the input list. Is it supposed to be there?“
There’s no way for the input list to “know” what the mic is, no. Doesn’t work that way.
Old 11-18-2023, 03:45 PM
Nope. Pro Tools has not idea what is connected to your interface, it can't tell and does not care, but you can manually edit these if you want.
When you click on Default on an Setup>I/O page all Pro Tools is doing is populating those I/O settings from the I/O port name information provided by the interface device driver. In most cases that is correct/useful info. But you can change all those names in Setup>I/O to whatever you want, and in serious recording sessions/recording studios etc. very typically the engineer (or assistant) *will* change many of those names to include microphone/preamp or other info.
Those names are only useful shorthand for the wetware (you) using Pro Tools. Pro Tools itself is always dealing with the physical I/O ports on an interface by the I/O port number.
The whole Setup>I/O system is beautiful to work with, but makes things complex for new users.
Old 11-18-2023, 03:46 PM
Now it appears to be working. But when I record my classical guitar, I get a muffling sound. And hardly picks anything up
I tried my voice and it works
I am getting close, just not able to put my finger on it now
Microphone is about 10 inches from my guitar
Record button on Avid keyboard signals volume, not record/ solution? soundartsonline Pro Tools 12 2 01-31-2023 05:18 PM
PT 12 selects record-enabled track or its section for edit after record pass dktstudio macOS 0 01-06-2018 08:29 AM
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts The Muphin Man Pro Tools SE and Essential (Win) 8 09-10-2010 07:03 PM
Master Record button doesn't record arm MIDI tracks? Borg ICON & C|24 1 10-29-2007 07:39 AM
