Old 11-24-2010, 06:05 AM
calvizio calvizio is offline
Default Protools 9 HD - 002r - Macbook Pro Intel Core 2 Duo 4GB
Anyone knows if this configuration is good enough to work?
thanks
Old 12-02-2010, 08:16 AM
Default Re: Protools 9 HD - 002r - Macbook Pro Intel Core 2 Duo 4GB
Is it possible?
Old 12-02-2010, 08:26 AM
Most likely it will work, but I expect you would need to set it up as an aggregate device thru core audio, which means you might not have the use of LLM(as long as you can record it a 64 buffer, that should not be an issue). Of course, if you just want to edit and mix(no recording) then all should be fine.
Old 12-02-2010, 01:58 PM
DigiTechSupt's Avatar
I do a lot of my work on a 2.2GHz MBP so, yeah, it's more than possible.
Avid Audio Tech Support
Support FAQ
Old 12-02-2010, 08:00 PM
Ragged Edge Ragged Edge is offline
I have that setup, pt 9 just does not seem to want to play nice with the 002r at all. All it does is present me with a dialog box informing me of a sample rate error when there simply isn't one. It will not play audio at all. I cannot, at this stage, recommend pt hd 9 with a 002r on a 4gb macbook pro.
Cheers,
Ragged.
[IMG] code is Off
Moving protools le 7(windows)to intel core 2 duo macbook pro oasis8916 Pro Tools TDM Systems (Mac) 2 09-14-2007 04:31 PM
moving protools le 7(windows)to intel core 2 duo macbook pro oasis8916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2007 11:22 AM
Intel 2 core dual Macbook Pro 2.33 and Digi 002r KMAN385 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-03-2006 11:06 AM
New MacBook Pro with Intel Core 2 Duo rogerhavoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-2006 01:17 PM
Intel Macbook and 7.1 002r Josiah LE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-07-2006 12:42 PM
