Old 07-12-2007, 01:30 AM
ld_neil ld_neil is offline
Default Quick Question - MBOX MINI
Hi there, I've had a search around but cant find an answer to this one. I am thinking about getting an MBOX MINI to get started with PT LE. Im a Logic user but want to broaden my horizons a little. I want to record voice and guitar through the Mbox but I also want to be able to use it as an audio interface for Logic as well. I have an old analogue hardware sound module that I have always wanted to get into Logic. Would the stereo L R output of the sound module going into the Mbox be available as an input in Logic?
Also is the headphone output on the Mbox assignable as a separate output? I would like to have the main output feeding monitors and then the headphone output to audition tracks in Ableton for DJ'ing.
thanks for your help!
_n_
Old 07-12-2007, 01:59 AM
sky88dd sky88dd is offline
Default Re: Quick Question - MBOX MINI
Yeah, you can use the Mbox Mini as your audio interface for Logic. Chosse the Mbox Mini in your system preference and I believe in Logic, you can choose a default audio interface in there.
The headphone out on the Mbox Mini actually mirrors the main outputs.
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Old 07-12-2007, 11:41 AM
ah cool thanks for the answer, another thing I thought of... When the Mbox is connected are you still able to use the Output 1-2 from the Macbook internal soundcard? I guess this would give you an output on the Mbox and another on the Macbook? Or is this output cancelled when the Mbox is connected?
thanks again
_n_
Old 07-12-2007, 04:50 PM
anybody know? thanks
quick question on mac mini gprok macOS 5 04-22-2013 01:05 PM
M Box 2 Mini. Quick question. harry3232010 macOS 1 09-27-2011 08:02 AM
Downgrading MBOX 2 to MBOX mini (Quick question) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 08:29 PM
Hey guys real quick ? about mbox mini Tronic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-20-2010 04:01 PM
quick question - Mbox Mini question - i forget JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2009 02:55 PM
