X-Mon same for Control as command?
I'm replacing a D-Command with a new D-control. Are the X-mon units identical? I don't want to re-rack the X-Mon if I don't have too.
Re: X-Mon same for Control as command?
Sound good to me.
Thanks Craig! |
There are differences. The D-control has 4 stereo ins, the D-command 3. D-control has 7.1 main and surround inputs, D-command 5.1 inputs.The D-control has 3 cues, the D-command 2.
Check if any of these matter for your studio. The connectors (db25) on the back of the XMon are identical and the pin-outs are as well if I'm not mistaken. Looks like the D-command XMON simple doesn't use some of the pins. I'd assume that there are differences in the analog circuitry between the 2 XMONs. Remove the D-command xmon and replace with the d-control xmon. All your current leads/snakes should work as before. Consider to add the connections above if you need it. Hope this helps. Best, Jan
2010 Dolphin Award for Production / Engineering AVID Certified Instructor |
Jan they are the same box, it's just how much is available given wether you have the D-Con or the D-Com
I have 2 D-Coms and 8 D-Cons, I can use any XMON on any surface
Hi Craig, that's interesting! Have you tried 7.1 monitoring with the d-command? If the xmon box is identical you should be able to hook 7.1 up and control volume from the D-command. Interesting!
J.
no, we don't do any 7.1
and the D-Coms are in out ADR and Foley rooms that are set up 2.0 only if I get some time this summer I'll try swapping a D-Con with a D-Com and report back but it will be late June at the earliest
Thanks Craig.
Would be nice if an AVID rep could clarify. The hookup-diagrams and pinouts diagrams in the OM don't give a clear answer here. It's irrelevant for cue3 and stereo4 as there are no controls for these on the D-command. But the Main/Alt outs... that makes sense! I wouldn't be surprised if the XMON units were exactly identical. The easiest way to find out is patch a signal generator across the 7.1 master-fader, bring the Main speaker volume up and check the output of the XMON C/R section. No need to swap consoles, just hook-up snakes that follow D-Control's pinouts (8ch) between interface and XMon in and XMON out to speakers. We'd have prove if signal appeared on all 8 outs. Interesting, interesting... J.
AFAIK theyre the same unit (current Avid staff please correct me if I'm wrong) - if you plug a 7.1 signal into an xmon connected to a dcommand you'll have dim and overall mute control but you wont have the individual solos/mutes as the buttons aren't there. That's what I was told when I asked this question a few years back.
(Hey Jan!) |
Good to hear from you Brent. Thanks for clarifying How are things going in Sydney?
Greetz from (rainy) Byron Jan
command 8 /control 24 or other control surface for HD | 68topls | Pro Tools TDM Systems (Mac) | 0 | 12-26-2009 12:25 PM |
Control 24 / command 8 or other control surfaces with HD | 68topls | ICON & C|24 | 0 | 12-21-2009 05:47 PM |
Tactile control of PTLE without Command|8 Control|24? | Blackshapes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-05-2009 09:39 PM |
Using D-Control/D-Command to control Pyramix | SoloMonk | ICON & C|24 | 1 | 10-18-2007 10:38 PM |
