Old 10-15-2019, 10:45 AM
James A. Abdo James A. Abdo is offline
Default Pro Tools won't unload (this is a weird one)
Symptom: Pro Tools 12 runs fine, but won't unload. Requires a reboot. Can't kill process with taskkill.
Short story: Pro Tools is my only audio application with this problem. All my other audio applications run and unload perfectly (Studio One, Sound Forge, Vegas Video, Reason, Sonar).
Long story: My studio computer (Win10, latest updates) is connected to my control room via CAT6 adapters (approximately 50 feet). If I connect my studio computer directly to my audio interface, or use the CAT6 USB extender with a short LAN cable (6 feet), Pro Tools unloads properly every time.
My audio interface is an RME Fireface UFX (latest drivers).
It is connected via a Sewell Ulink UL10 USB 2.0 extender.
https://sewelldirect.com/products/u-...-cat5e-6-200ft
Any thoughts would be greatly appreciated. Even if there was a way to kill the process.
Thanks in advance,
~jim
James A. Abdo
BrokenWorks Productions
Old 10-15-2019, 11:08 AM
Default Re: Pro Tools won't unload (this is a weird one)
It’s not unheard of, been many posts on DUC over the years.
One suspect is a bad plugin. (Possibly even one you are not using).
Does it happen with all sessions or just some?
Try trashing prefs first... does that fix it?
Move all the .aaxplugin files out of the plugin folder, trash prefs, restart pro tools. Open a session that did it before. Quit... is the same problem there? There is you make a change in the session and quit and try to save?
Old 10-15-2019, 11:17 AM
Thank you Darryl.
I've tried deleting the Pro Tools app data folder -- same problem.
I will try moving the aax files ASAP, and get back to you.
James A. Abdo
Old 10-15-2019, 11:18 AM
Be sure to fully trash prefs as you go. Use Pete Gates PT Prefs utility.
Weird Pro Tools 11 Problems Billy Germano Pro Tools 11 1 07-28-2013 03:41 PM
Pro Tools weird CPU issue mpeg5 macOS 10 03-02-2012 07:21 PM
Pro Tools HD 8 really weird problem. rolling_beat Pro Tools TDM Systems (Mac) 17 08-13-2010 09:46 AM
Pro Tools 8.03 LE Weird bug risey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-31-2010 02:46 PM
Weird Pro Tools Error Keith Moore Pro Tools TDM Systems (Mac) 2 08-21-2006 11:03 AM
