#21
Re: Which processor is better for Pro Tools M-powered
Not where Pro Tools is concerned. It doesn't matter how fast your processor is; if the program interferes with Pro Tools, it interferes with Pro Tools.
#22
Which is faster: a 3 Ghz dual core or a 2,5 Ghz Quad core ?
#23
I'm gonna try to reinstal windows but if it still not work i think i have to change with a dual core duo 3 ghz or something with higher frequency. When i used the single core this problem wasn't that bad.
#24
I installed windows again, but still didn't resolved my problem.
#25
I set Pro Tools playback engine Rtas to 3 processors and it's a little bit better. But i am not fully satisfied because if i grab the transport bar while playing a project and move around it's not playing well and the processor goes to 100%.
#26
Can you post a new Sandra report from you new install?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#27
sandra report http://www.zshare.net/download/64440493a66ce699/
#28
You only need to post the computer overview, and that zShare.net site has some very questionable pop-ups. One was blocked by my security software, so you might just want to do a scan of your system.
This is all you need to post from that report: Code:
<<< Computer Overview >>> -------------------------------------------------------------------------------- < Computer > Model: System manufacturer System Product Name Workgroup: WORKGROUP Host Name: acasa-e89a1df95 User: Paul < Processor > Model: Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz Speed: 2.5GHz Cores per Processor: 4 Unit(s) Threads per Core: 1 Unit(s) Type: Quad-Core Integrated Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < Computer > Mainboard: Asus P5Q SE2 BIOS: American Megatrends Inc. 0406 10/07/2008 Bus(es): ISA X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 3GB DIMM DDR2 < Chipset > Model: ASUS P45/P43/G45/G43 DRAM Controller Front Side Bus Speed: 4x 334MHz (1.34GHz) Total Memory: 3GB DIMM DDR2 Memory Bus Speed: 2x 334MHz (668MHz) < Memory Module(s) > Memory Module: Kingmax KLCD48F-A8KB5 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module: Kingmax KLCE88F-B8KU5 2GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) < Video System > Video Adapter: NVIDIA GeForce 8600 GT (32 SP 1.1GHz, 512MB DDR2 2x400MHz, PCIe 1.00 x16) < Storage Devices > WDC WD1600AAJS-00PSA0 (160GB, :149GB (C:) (D:) ST3640323AS (640.1GB, SATA300,:596GB (E:) HL-DT-ST DVDRAM GSA-H10N (ATA3:N/A (F:) TCL LMJCPI3 (SCSI, BD-R, HD-DV:N/A (G:) < Logical Storage Devices > Hard Disk (C:): 49GB (NTFS) @ WDC WD1600AAJS-00PSA0 (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Hard Disk (D:): 100GB (NTFS) @ WDC WD1600AAJS-00PSA0 (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Local Disk (E:): 596GB (NTFS) @ ST3640323AS (640.1GB, SATA300, 3.5", 7200rpm, NCQ) Optical Drive (F:): N/A @ HL-DT-ST DVDRAM GSA-H10N (ATA33, DVD+- RW, CD-RW, 2MB Cache) Optical Drive (G:): N/A @ TCL LMJCPI3 (SCSI, BD-R, HD-DVD-R, DVD+- R-DL, CD-R) 3.5" 1.44MB (A:): N/A < Peripherals > LPC Hub Controller 1: ASUS LPC Interface Controller LPC Legacy Controller 1: T0 A5-13h Audio Device: ASUS HD Audio Controller Audio Device: VIA M Audio Audiophile Serial Port(s): 1 Disk Controller: ASUS 4 port SATA IDE Controller Disk Controller: ASUS 2 port SATA IDE Controller Disk Controller: ASUS 6101 SATA2 Controller USB Controller 1: ASUS USB UHCI Controller #4 USB Controller 2: ASUS USB UHCI Controller #5 USB Controller 3: ASUS USB UHCI Controller #6 USB Controller 4: ASUS USB EHCI Controller #2 USB Controller 5: ASUS USB UHCI Controller #1 USB Controller 6: ASUS USB UHCI Controller #2 USB Controller 7: ASUS USB UHCI Controller #3 USB Controller 8: ASUS USB EHCI Controller #1 SMBus/i2c Controller 1: Intel 801xx/63xx SMBus < Network Services > Network Adapter: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance: x86 According to the ASUS website, you are WAY behind on the BIOS version. The current one is 0601. I would definitely recommend getting current on the BIOS. Disable the NIC when running Pro Tools (and when running reports about your problematic Pro Tools system ) What model BluRay hardware is that? It doesn't look familiar. If it is a "virtual disk" (it looks like it could be) you need to be absolutely positive that it is disabled when running Pro Tools. Not just un-mounted, but disabled.
#29
I've have PTLE running on a P5Q SE2 so its probably more of a configuration issue than a major hardware conflict.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#30
mac osx, m powered fast track, pro tools m powered | singdance6 | Pro Tools M-Powered (Mac) | 2 | 12-22-2010 09:24 AM |
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? | jeremiah0812 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-19-2010 10:10 AM |
optimizing processor power for PT M-Powered | nonsqtr | Pro Tools M-Powered (Win) | 1 | 10-03-2010 03:03 PM |
Help building a quiet quad processor PC for M-powered. | headswimmer | Pro Tools M-Powered (Win) | 0 | 05-20-2008 01:29 AM |
M-Powered on Cube with faster processor? | John Link | Pro Tools M-Powered (Mac) | 5 | 03-04-2006 06:30 PM |
