Re: RTAS VI's still very inefficient
I print EVERY SINGLE instrument. Version updates, session load times, old session recalls, CPU stress, opening on different systems, opening session on different platforms,
audio timing is tighter than midi, fewer memory issues. There are are dozens of reasons to print and not a single GOOD reason NOT to. I can't tell you how many times times this practice has saved my back. |
And a good reason not to do it; don't want to. Just a thought..... avid is well aware of the inefficiency of rtas in comparison to vst and au. This has been a complaint for many years. certainly hope something is in progress to get it updated and more efficient.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
The good reason not to print to audio is if you're working in film and the filmmakers are re-editing all the time. One used to get locked picture and have time to work with that, but the expression "locked" is fast becoming a quaint anachronism.
Under those circumstances, staying in midi makes more sense and doesn't add the clutter of unusable soundfiles that no longer match the picture. |
to the above Poster VI's shift in MIDI timing. all the time that's WHY you should ALWAYS PRINT. Plus now with HEAT you audio must be printed anyway. That's where really comes into play nice on VI's Not priting is going to give a hundred times more headaches that printing ever will. |
For the best of both worlds, print at the end, not during.
I print sometimes, and then i just use hide and make inactive on the Instrument track. If i need to make any changes just show and make active again.
PC 7980XE @ 4.2 PT 12.7 Ableton 10.0.1 Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650 IS Pro Double 6" Speakers, www.intelligentsound.se/ |
yep. this works fine for me as well.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Can't you just print to audio and then, after saving the settings of the VI, get rid of that VI while saving/hiding the instrument track with the MIDI recording?
This way you have lost the CPU intensive VI but you still have that MIDI performance and if you need to you just dial up the VI according to your notes. Yes, the RTAS environment is very inefficient.
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
Interestingly though, this only goes for RTAS VI's.
RTAS insert plugins are about the same as their vst/au counterparts. |
ReWire multi-out setup is inefficient, Avid please update. | kwz | Virtual Instruments | 1 | 02-07-2013 01:00 PM |
Is RTAS really that inefficient ? | P4Vi7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-25-2010 02:18 AM |
TDM more inefficient than RTAS. | bunkker | Pro Tools TDM Systems (Mac) | 11 | 04-28-2010 10:25 PM |
50 Spectrasonics VI's, 50 NI VI's and 50 structure all in one pro tools session | crizdee | Pro Tools TDM Systems (Mac) | 11 | 04-03-2010 09:03 AM |
VSTwrapper non "RTAS optimized" VI's+2processors? | spiritG | Pro Tools TDM Systems (Mac) | 2 | 11-26-2006 02:15 AM |
