Re: Axiom Pro/ProTools9/Hypercontrol problem
It's a firmware update that Axiom Pro requires.
Aaron Mulqueen - 001 HD Native |
Where to get?
Can't find it on m-audio.com But i think i have the latest anyway...!?!
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
So.....
...is it an Axiom Pro problem, HyperControl or ProTools9?
Personally, I think it's a HyperControl and Pro Tools functionality problem.
If you didn't have those problems on an ulterior version of PT, and everything worked as they should have on PT 7 or PT 8. Then you know it's PT 9 and what relates to it, that is having the problem, not the controller itself.
#16
True however what happens when symptoms were observed with previous configurations of revision and controller and the addition of a new revision accumulates more symptoms? Should I take the kid to the doctors?
#17
I have a Axiom Pro 61 using with Pro Tools 8 (latest version 8.0.4) and have the same problems. Starts working fine and soon after that the display freezes when in instrument mode and that's it...
#18
Can you recreate this freeze phmrodrigues? Can you create a list of steps to go through to recreate this freeze?
#19
Anyone experiencing problems like this on the Windows PC front?
Mine works great. On Mac Osx the behavior seems erratic. Pressing the numeric keypad (3) toggled between the mix window and midi edit window. When prefs are trashed and new session is started, all works as it should until you close session and relaunch at later time. I wonder if this is why new axioms were produced with DirectLink. It seems that Avid/Maudio are trying to quietly bury hypercontrol and sweep this under the rug. I hope that this is not the case. |
#20
Where is the substance to back this statement up?
pro tools m-powered 7.4 + axiom pro 61 + hypercontrol | Cbeaulne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-19-2011 11:54 AM |
axiom pro hypercontrol and pro tools - why no workie? | tunespin | MIDI | 10 | 09-28-2010 11:31 PM |
Axiom Pro - Hypercontrol keyboard w/Protools 8 LE | shawnusa | MIDI | 20 | 06-06-2010 01:25 AM |
Axiom Hypercontrol vs D Command | SaturnSound | ICON & C|24 | 1 | 05-03-2010 03:06 PM |
Windows 7 + Axiom Pro Hypercontrol = Not working? | DeyBwah | MIDI | 8 | 04-28-2010 07:21 PM |
