Old 07-24-2001, 07:14 PM
zedhed's Avatar
zedhed zedhed is offline
Default red \'peak \' LED light stays on.
After going into 'setup preferences' and selecting either 'no peak hold' or '3 sec peak hold' the led stays red after hitting a peak once(on any given channel). I would really rather not have to keep clicking on the red LED to get rid of it every time a signal hits peak. Any ideas on how to rectify this?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 07-24-2001, 08:04 PM
ReniuR ReniuR is offline
Default Re: red \'peak \' LED light stays on.
That option applies only to the little line that that indicates peak within the meter.
-ReniuR
www.disposableproductions.com
Old 07-25-2001, 03:09 AM
NoviceDollars NoviceDollars is offline
I didn't think it affected the track, just indicated that clip occurred.
Sean
Cost of Living
Old 07-25-2001, 05:31 PM
mfym mfym is offline
The only way to rectify this problem is to record the track at a lower level.
A compressor in-line would squish the signal some before recording and allow you to record a hotter signal.
You could also use the gain plug-in in Audiosuite and reduce the level.
Hope this helps. [img]images/icons/smile.gif[/img]
Old 07-26-2001, 12:11 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by NoviceDollars:
I didn't think it affected the track, just indicated that clip occurred.<HR></BLOCKQUOTE>
Right. I'm talking about the little line that follows the green portion of the meter and stays at it's peak (NOT the red clip light). The option you mentioned applies to that little line, infinate hold will keep the line at the highest point (up to the red clip light) until a louder part bumps it up more, and 3 sec hold will only display the line at it's highest point for 3 seconds, then it refreshes.
[ July 25, 2001: Message edited by: ReniuR ]
-ReniuR
Old 07-26-2001, 06:11 AM
zedhed's Avatar
I sort of thought the level meters would act like on a console, hit red to show a transient spike and then go out so it could show the next transient peak. I like to run as hot a signal as I can without squashing it with limiting or compression.I like to adjust the fader on the fly, but have to keep clicking on the red 'clip' light to get rid of it.So I don't really know where my 'hottest' signal level actually is.
HD 96I/O
Old 07-26-2001, 09:32 PM
Mr_Seven Mr_Seven is offline
(Workaround) You might try normalizing or droping the gain after recording to get the level so as not to peak.
Darren Valen
Cyberdream Studios
Mbox Pro 3 blue light stays on but has the status of "Hardware not connected" Focuret FireWire & USB Audio Interfaces (Mac) 1 01-15-2014 12:18 AM
USB 3.0 and/or Light Peak JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-20-2010 07:34 PM
A quick peek at New HD hardware and Light Peak... Citrin Pro Tools TDM Systems (Mac) 14 09-24-2010 03:43 PM
Peak LED stays on - Huge issue!! neeel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-01-2008 12:04 AM
Mbox Peak / Peak Light Issue soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-29-2004 08:01 PM
