12.8.2 Broke Layered Editing Feature??
Hi guys
Today i found that, when i have Layered Editing enabled,and drag a clip over another and then moving it,it deletes the whole clip region..i made i small video to check it Is this supposed to happen?I think no,watching this https://youtu.be/_jyYYNtCDyI?t=5m25s However,when i just hit delete on the above clip,the underneath clip remains as it should... https://www.dropbox.com/s/5wxxde0az4...20Bug.mp4?dl=0 |
Re: 12.8.2 Broke Layered Editing Feature??
If a clip is fully overlapped by the clip on top, the underlying clip will be removed from the timeline. Is that what you're seeing?
No,watch my video If i drag a clip on top of another and then moving that clip,then it leaves "hole" Meaning,it doesn't retain the underneath clip! |
Ah, sorry. I missed the dropbox link.
I don't use this feature, but I will do some tests.
Yes,please test it...as you see from the youtube link i provided ,this shouldn't be happening |
I'm seeing the same behavior as you, I believe. Moving (click'n'drag) a clip leaves a hole, but cutting/deleting an overlying clip does not. Seems like erratic behavior to me.
PS: This is on PT 12.7.1.
Maybe it's a bug which no one realised till now?hah
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Seems like you are using HD maybe it's broken in vanilla,like the vcas in 12.8.2x105 |
I am experiencing the same issue. I'm on the HD
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
PT 12.8 Bug - Layered Editing doesn't turn off | alejocazu | Pro Tools 12 | 10 | 10-31-2017 07:49 AM |
Layered Editing Bug in Warp mode | loopzilla2 | Pro Tools 12 | 2 | 12-13-2016 11:17 AM |
12.6 Layered Editing? | ptfigg | Pro Tools 12 | 6 | 11-30-2016 10:58 PM |
12.6 layered editing not what it should be | pyrmont25 | Pro Tools 12 | 8 | 09-29-2016 03:02 PM |
PT LE for feature dialogue and fx editing | ant.s | Post - Surround - Video | 17 | 01-22-2005 11:03 AM |
