Old 10-03-2016, 10:18 AM
ptfigg ptfigg is offline
Default 12.6 Layered Editing?
I'm not seeing any difference in behavior with or without Layered Editing enabled.
With Layered Editing disabled - if I drag clip A over to and partially on top of Clip B, a new edit point is created. If I then drag clip A back to it's original position, both clips return to their original state in terms of duration. I don't see any difference in behavior when Layered Editing is enabled.
My interpertation is without Layered Editing, when you drag one clip over another, the lower clip is "cut" and the handles are removed creating a shortened clip. Conversely, Layered Editing retains the handles of the lower clip.
Am I misinterperting the process in general?
Thanks.
-paul.
Old 10-03-2016, 10:24 AM
Default Re: 12.6 Layered Editing?
Thanks.
-paul.
There are a couple added pref settings to also be aware of. Fully covered clips can be sent to a new playlist. This can be set to editing or recording or both.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 10-03-2016, 10:29 AM
Thanks. I'm aware of the Preferences. So, Layered Editing is only relevant when Playlists exist?
Thank again.
-paul.
Old 10-03-2016, 10:32 AM
Thank again.
-paul.
No, I was just pointing that out in case you were not aware. I would say to check the docs for this as it would probably explain it best.
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 10-03-2016, 10:40 AM
midnightrambler midnightrambler is offline
Layered editing in 11 seconds : https://vid.me/OGBi
Not sure if I really need it to be honest, having not had it for the last 16 years....
Old 10-03-2016, 10:49 AM
Yup - I see it now, and it's exactly what I expected in terms of behavior. For some reason it wasn't working in this old test Session that I was using. I created a new Session with new clips, and it works as expected ... so thanks.
-paul.
Old 11-30-2016, 10:58 PM
Dizzi45Z Dizzi45Z is offline
-paul.
I have the exact issue you originally described where turning layers on or off doesn't make a difference. This is especially when the grabber tool is in Time mode. For me, it always acts as if it is in layered mode which is what I prefer anyway.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
12.6 layered editing not what it should be pyrmont25 Pro Tools 12 8 09-29-2016 03:02 PM
Why Pan Layered Sounds In XPAND2 If.. MIKEIKE Pro Tools | Intro Discussion 0 10-06-2015 12:43 PM
Midi to audio layered tracks bobbyrichards Pro Tools 10 0 03-27-2013 01:28 PM
how to swap layered, looped takes in pt8? c-post Pro Tools TDM Systems (Mac) 4 03-11-2013 04:32 AM
Creating a Layered Instrument...Using Xpand! Avid Virtual Instruments 0 02-15-2006 07:40 PM
