Old 06-14-2016, 02:27 PM
Vilming Vilming is offline
Default DPI scaling bug when using AIR plug-ins
Well, I downloaded and tested 12.5.1 as soon as it appeared. Having waited since 31 March for this update I found the same old DPI scaling bug is still present in 12.5.1. Screen shrinks to quarter of size for all projects having AIR plugins on my 4k display with 200% DPI scaling, making it virtually impossible to see what I'm doing. Submitted support case (again). Back to 10.3.10, which still works OK... Let's wait and see what 12.5.2 brings.
Last edited by jeffro; 06-15-2016 at 09:24 AM. Reason: Moved to new thread to raise visibility.
Old 06-14-2016, 05:16 PM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
Default Re: Pro Tools 12.5.1 Update Now Appearing In Avid Accounts
All included AIR plugins and instruments (e.g. Mini Grand, Xpand2, Boom, ...) remain unusable for those of us on 4K displays at 3840 x 2160 with DPI scaling.
So does the AIR Instrument Expansion Pack (Hybrid 2, Strike, Transfuser, Structure, ...).
According to AIR, this is an Avid issue: http://community.airmusictech.com/ai...esktop-scaling -- see latest posts.
Come on Avid, please fix this!
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
Old 06-14-2016, 07:03 PM
unkJE's Avatar
unkJE unkJE is offline
Thanks for posting this.
As the year-old Thread in your link (on the AIR Music Tech Community Forum) ends with: “Funny thing I go and try it again just to see if anything had changed, and everything is fixed!” – I’ve just raised this issue again on the AIR VI BETA FORUM (where issues with AIR Instruments and Plug-Ins are raised).
I will post back here, if & when I hear any more info.
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 06-15-2016, 06:54 AM
DetroitT's Avatar
DetroitT DetroitT is offline
What Video Card and driver version?
Brand of 4K Display (Firmware checked?)
HDMI cable 4K capable?
Your details posted could help.
Old 06-15-2016, 09:11 AM
DAWgEAR's Avatar
My specs are:
NVIDIA Quadro K600, driver 362.13
ASUS PB287Q 4K Display via Display Port @ 3840 x 2160, firmware N/A
Windows 10 Pro 64
Old 06-16-2016, 11:31 AM
iceblueD iceblueD is offline
Default Re: DPI scaling bug when using AIR plug-ins
Been having the same issues with my ASUS N501JW Laptop. It has a 4K display built in and even with scaling at 300% its almost unusable.
Daniel J. Webb
Old 06-16-2016, 11:55 AM
biasrocks biasrocks is offline
Try going into the Pro Tools properties and disable display scaling at High Resolution.
Right click on the Pro Tools icon
Properties
Compatibility
Click -> Disable display scaling on high DPI settings
This is on Windows 7 x64, I'm sure it's similar on Win 10.
I find this makes Pro Tools appear much better and may solve your issue.
Mark
Old 06-16-2016, 07:02 PM
DAWgEAR's Avatar
Properties
Compatibility
Mark
Thanks, Mark, but this is not the solution.
I am running 3840 x 2160 with 200% scaling within Windows.
Disable display scaling on high DPI settings prevents Pro Tools from scaling. It "solves" the problem by making the unscaled Pro Tools interface just as tiny as the AIR plugin interfaces.
With Disable display scaling on high DPI settings unchecked, as I an running it, Pro Tools scales correctly and all plugins I have (e.g. Waves, UAD, Soundtoys, FabFilter, Sonnox, Native Instruments, Toontrack, etc.) scale correctly within Pro Tools. To my aging eyes, Pro Tools looks great at these settings.
The non-AIR Avid plugins that come included with Pro Tools such as EQ3, Dyn3, D-Verb, and Channel Strip also scale correctly.
It is only the AIR plugins that come with Pro Tools such as AIR Flanger, Mini Grand, Xpand2, and Boom that have this issue. Any additional (not included with Pro Tools) AIR plugins such as Hybrid, Transfuser, Velvet, and Strike also suffer from this issue. They take the entire Pro Tools interface with them -- the whole thing becomes unscaled, not just the plugin GUI. Quitting and restarting is the only fix.
The thread I linked to above indicates that this once affected other hosts and not just Pro Tools. If the official responses from AIR in that thread are accurate, the issue has since been addressed on AIR's end but there is still something that Avid needs to address as well.
My solution has been to move all AIR plugins to the unused plugins folder and replace their instances with plugins from other companies. Not really satisfactory since the included plugins are part of the product that we paid for with Pro Tools initially and again with $599 (HD) for the current year's support.
Old 06-17-2016, 02:27 AM
unkJE's Avatar
Good news: a fix is currently being worked on.
I got this info from the AIR VI BETA FORUM:
"We are working on modernized GUI implementations with full HiDPI support, but this also requires all the artwork to be rerendered in higher resolutions which is a major undertaking."
Old 06-17-2016, 10:38 AM
DAWgEAR's Avatar
Thanks for the update, unkJE!
Hope this does not take too long.
Automation Scaling Arya44 Tips & Tricks 4 02-19-2020 09:08 AM
GUI Scaling problem on W10 APM Pro Tools 12 1 11-25-2017 05:11 PM
PT 12.3: 2x Xeon CPU scaling ready? astroturf Pro Tools 12 3 12-17-2015 12:33 PM
Scaling MIDI data Brent1515 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2007 05:06 PM
Automation Scaling? decibel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-13-2002 12:20 AM
