C24 fader touch issues
I just hooked up a C|24 and the faders are responding strangely. In the test area, the faders register touch but it flickers on and off, and sometimes not at all. If I touch a group of faders they register the touch correctly. If I try to move an individual fader, the the motors fight against it. This happens outside of ProTools too. Could the power supply be faulty?
I have tried disconnecting/swapping ethernet cables, power cables, etc. Any help would be greatly appreciated! |
Re: C24 fader touch issues
C/24>calibrate faders. Also note that finger needs to be on the fader, touching the top or bottom edges will be intermittent (Can't feel the heat)
Yes, I've tried calibrating through the on board tests/prefs, but the touch is still only reading intermittently. I know they need to be touched on the top but it's not making a difference. The only time the faders read the touch correctly is when I'm touching more than one simultaneously.
There's a test mode in the Utility menu, that allows you to check the touch sensor readings. You can see there how the frequency changes when you touch one or more faders. If you write the result here, I can tell you if your readings are different from mine.
DetroitT: They don't feel any heat, they are electrically conductive and feel the capacity of your body.
BcA. Tomas Vitha Sound Designer and Mixer 2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24 |
Before this thread goes downhill really quickly...
... and feel the capacity of your body. It's capacitance BTW: It's the same principle used by condenser mics...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Ran through the touch tests and the touch seem to be registering intermittently, so it looks like it's a capacitance/grounding issue. I've checked the electrical sockets and the wiring is correct, but I still have the problem. There is nothing else in the room besides the board and desk, so I don't think it's an rf issue. Tried with lights on and off as well as sometimes halogens can generate rf, but no difference. As soon as I ground myself to the desk, board, or power supply, everything works correctly. Any ideas on how to remedy this?
ziggy2282
You wouldn't happen to be a guitarist with thick callouses on your fingers? That definitely impedes the faders picking up contact.
Dave Marsden UK |
I have the exact same issue, did you ever figure out what it was?
Windows 7 Pro 64-bit Intel Core i7-2600K @4.5GHz QUAD 8 MEG CACHE W/HT LGA1155 Motherboard dual channel DDR3 TI firewire (Sandy Bridge) Mushkin DDR3 16G RAM Pro Tools HD Native 9.0.5 C24 Eleven Rack Lynx Aurora, LTHD UAD2 Quad Neve ----------------------------------------------------------------- MacBook Pro 2.3GHz Quad-core Intel Core i7 8GB 1333MHz DDR3 SDRAM Pro Tools LE 8 Glyph Tech GT050Q 003 Rack Mbox2 mini |
You should check the outlet to see if it has a good ground. Put a humidistat in the room and see how dry it is. If its really dry, stick a humidifier in a corner. Maybe attach a piece of 10 gauge wire to the back panel and run it to ground? Proper grounding is required for this function(so make sure nobody hacked off the ground pin on the power cord too)
Touch fader control for iPad | Soldier69 | VENUE Live Sound Systems | 11 | 06-11-2013 09:59 PM |
Fader not responding to touch | PTPerson | ProControl, Control|24, Command|8 | 5 | 06-09-2012 12:29 AM |
MC mix fader doesn't respond to touch | Neale Eckstein | Artist Series | 3 | 01-05-2011 09:44 AM |
Touch beside the fader mutes the channel... | webstereo | ICON & C|24 | 2 | 08-24-2010 07:02 AM |
C24 Fader chatter on Auto Touch... | Raven | ICON & C|24 | 1 | 05-18-2002 10:18 AM |
