Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 05-22-2007, 09:23 PM
naughty naughty is offline
Default BOUNCE TO DISK
Why is pro Tools just about the only system without internal bouncing? Its a pain in the a__ to sit and listen to it bounce, only to get to the end of a song, then drop out. Has anyone brought this up at digidesign? This needs to be a feature in the next update to pro tools.
Old 05-22-2007, 09:54 PM
Jim Casey Jim Casey is offline
Default Re: BOUNCE TO DISK
it happens I find because of lack of automation thinning or too many programs on the machine running in the background - use a clean boot and you should be fine
Casey
You can hear what I'm doing at:
http://www.reverbnation.com/jimcasey
Old 05-24-2007, 01:25 PM
stmiller stmiller is offline
Yes this is greatly needed, I agree. I have been recording audio in Pro Tools then using Audacity or Logic to make a quick bounce (off line) of the session.
Old 05-24-2007, 02:03 PM
LeGato LeGato is offline
I wouldnt trust a function like that in PT, the BTD is bad enough in realtime. At least with RTD( record to disk) it'll sound accurate.
Old 05-24-2007, 05:16 PM
I have found that in Logic and other programs that the offline bounce is much more accurate and uses less CPU. Doing a realtime bounce takes more resources as everything has to render and playback.
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 07:16 PM
could not complete the bounce to disk command because: a disk is full -34 help? Henrydm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-27-2010 09:07 AM
LE's Bounce to disk vs. Reaper Render to disk gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-16-2009 04:49 PM
Bounce To Disk inserts silence at start of bounce - PT 6.4.1 innerbooty Pro Tools TDM Systems (Mac) 1 04-18-2007 08:13 AM
