Major Pro Tools Problems
Hey Yall...
I have major Pro Tools problems! Buffer errors... Access violation errors... Pro Tools unexpectidly quits... Dae errors... sometimes Freezes on loading up at "Creating Dae objects"... basically its very unreliable... it sucks. Here are my specs: PC: Windows XP Service Pack 2 Original Copy P4 3.2 GHZ MSI Core Cell Mother board 800 FSB (i think) 2 gigs or ram !!! (that shud be more than enuff) Audigy 2 Sound Card FireWire Card M Audio Midisport 4x4 Plextor DVD pkayer / cd burner Hyper Media 52X cd burner Artic Coling Huge Fan for The P4 chip My Pc case side panels are off, in a very cool AC room (for cooling issues) 200 GB Maxtor Drive 120 GB HD with 3 partitions Theres Plenty Speed, Plenty Space, plenty Cooling.. What Is Wrong?! Thats Basically my PC components... I have rebuilt this PC over and over from scratch, I have not yet found a reliable Pro Tools setup... Im beginning to think pro tools le just sucks. Studio: Digi 002 Console Maxtor External Harddrive 250GB Micro korg Midi Keyboard AKG C2000B Shure 600$ mic (cant remember the series) As you can tell im very frustrated with this. Who wouldnt be? Plz help me out... My sessions are getting tp be embarrasing Thanks in advance |
Re: Major Pro Tools Problems
Sorry Guys... Im running Pro Tools 7
Have you checked the compatibility?
* not that i can help, i think the people that can would want to know which motherboard you are using.
http://bobbybloomfield.com |
#1. Do your self a favor and check if your computer (mother board chip set) is compatible. after you do that, people here can continue to advice you.
Camilo Toledo |
Mine is 865G Neo 2-P ...
Digidesign's list: Asus P4C800-E motherboard Intel 845/845E/845PE, 850/850E, 865PE, 875P, 915GL/915GV, 925XE, 945G/945P*, 955X* chipsets with Intel Pentium 4 processors There is a 865 on the list but not "G" so that could be a problem... or THE problem???? |
Have you tried everything in the General Troubleshooting thread? (including the sandra report...)
Meanwhile try uninstalling the Audigy and run without it to see if that helps.
One Problem.... The audigy is my only Firwire ports... i have to plug my digi 002 into the Audigy 2 soundcard to run it. I think, i know that should be bad, but i have no other way to do it. I bought a 3 slot firewire card but it has major problems... i get more buffer errors and firewire errors than ever with my firewire card. So the sudigy is the best way for me to go... I dont know what to do guys. Yes i have went throught the troubleshooting for digidesign... no help.
Im gonna buy a Powerbook G4 17 inch 1.6ghz soon. I just want to get this machine of mine working so that i can record until i get my powerbook (in 2months). So anyone have any more help? Thanks in advance... |
To me it sounds like a firewire issue. I would check the compato page and find out
which cards are supported. The Audigy is rather flakey as it is,let alone using it's onboard FW connection. There could even be a IRQ sharing issue there. I would hold out for that Powerbook rather than spending the money on another FW card unless you have a good return policy of course and how badly you need that setup to get you by.
2006 'Blackbook' Core Duo 2.0 ghz. 2 gig OWC RAM 10.5.8 PT Mpowered 8.04, Logic 9.1.1 Waves SSL,Omnisphere,Korg Legacy Digital Absynth 4, EZ Drummer Project Mix I/O w/ Black Lion Mod Axiom 61,25, Korg Nano Pad |
Two things:
In the first post you say you have an "MSI Core Cell Mother board" then later you state you have an "Asus P4C800-E motherboard". Which one is it? If it's an MSI those have been problematical in the past. And, yes you need an approved FireWire card. Many problems have been solved just by using a compatible/recommended FireWire card. Happy New Year!
Pro Tools HDX useless?!?!?! major RAM usage problems 32bit | dustin_m | Pro Tools HDX & HD Native Systems (Mac) | 33 | 11-11-2019 10:49 AM |
Major problems wih Pro Tools 10 and Digi003 Factory AND Mbox 3 mini | DanielWiklander | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-11-2013 01:05 PM |
Major problems getting pro tools to work on my new mac | Jabes75 | Pro Tools M-Powered (Mac) | 10 | 01-25-2011 02:58 PM |
MAJOR problems with dig001, pro tools 6.1.1 on Win XP HELP! | i3eezenotch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-07-2007 03:45 PM |
Dubbing Major Pix, Major Problems | BigBobMXMan | Pro Tools TDM Systems (Mac) | 0 | 07-15-2001 01:43 AM |
