Old 11-05-2004, 05:26 PM
EthanMorse EthanMorse is offline
Default PT6.7 & Reason 2.5 buggy.
I wish I could detail how to reproduce this bug but it seems like it's just random. Every now and again when using reason with PT through rewire, PT "forgets" about reason, and reason instruments just don't get played back. So then I close both reason and PT and start them back up and PT states that the Reason Plug-In can't be found and makes the insert inactive. The issue doesn't get fixed until I reboot. I didn't have any problems in 6.4 using reason with PT. I was actually impressed with the solid stability of 6.4 with reason since I work them both pretty rigorously, but I just upgraded to 6.7 and I'm having problems.
G4, 733, 1G Ram, HD2
Old 11-06-2004, 02:23 AM
TCDet TCDet is offline
Default Re: PT6.7 & Reason 2.5 buggy.
Are you using Aux or Audio tracks?
I have not had this on my system.
I have come into the Rewire routing bug.
I can route rewire 1-10 in stereo pairs fine but when you select “11-12, 13-14”....
(on stereo aux tracks) it connects “11-10, 13-12” respectively. Not only are the numbered connections inverted and offset buy -1 in order, they don't connect as labeled.
This is repeatable:
Open a new session, add 7 stereo aux tracks, insert RTAS Instrument Reason, then assign the reason outputs. For my system it is after the 9 and 10 outputs when it falls apart.
The workaround is to go back to mono rewired aux tracks which works.
Reason (Full) 2.5
PT's HD3a-1x192, PT’s 6.7
G4 QS2002 dual 1Ghz, Mac OS 10.3.5
Atto 3.1, UL3D SCSI, Built in FW
PT 11 Buggy for sure bonzerboy Pro Tools 11 1 01-02-2014 05:59 PM
Is it me or is PT 8.03 buggy? Eric L Post - Surround - Video 1 02-26-2010 01:48 PM
buggy buggy buggy,,,, shutiri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-08-2007 10:08 PM
iTunes 4 and Mbox are still a bit buggy (or I'm I buggy) Pat Thrall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-24-2003 11:01 AM
SSC buggy? MilesMusic Digidesign Hardware & Software 0 05-06-2002 03:22 PM
