Old 03-06-2013, 03:45 PM
dustin_m dustin_m is offline
Default Re: Pro Tools HDX useless?!?!?! major RAM usage problems 32bit
Hi Stewart,
Sorry if I came across the wrong way. I appreciate the time you took to respond. I'm just trying to connect with others who are experiencing these problems. Unfortunately I wasn't the one who decided to make the jump to HDX but inherited this problem from a tech who is no longer working with us. I understand your argument but it's difficult to see how Avid is plugging their system as the most powerful, professional one in the world if we are running into these problems. I know the system will be great, however in it's current state it's anything but. I know this isn't Avid's fault but 3rd party companies that need to catch up. However most other DAWs have some plan for these natural limitations of 32bit programming, and I had hoped "Pro" tools would have as well.
Anyway, I was actually hoping for this thread to be about the problems and possible workarounds for those who are running into these problems (or others) and not a discussion about Avid's roadmap forward or a debate about wether or not HDX is ready for primetime. I'm sorry if I seemed short or dickish earlier.
Old 03-08-2013, 04:06 PM
Mixchump Mixchump is offline
Dustin,
I just did a ground up reinstall on 10.7.0 and combo updates to 10.7.3 then 10.7.4.. ProTools 10.3.3.
It seems to me that the whole computer, ProTools included, is much more responsive, than on 10.8.x.
I did the SUDO command for persistent 32Bit Kernel, because they way I see it, until the very last plugin that I use is ported to 64Bit, I'm basically risking stability if I go there.
I'm REALLY hoping this is going to be more stable than ML. Next week, I'm reprinting mixes (and alternates) for an entire album (for free) with client in attendance (do you think they trust me and ProTools right now?).
Does anybody know what AVID is officially putting forward as the approved configuration for HDX right now?
I'm running Waves 8 right now, and I'm loathe to WUP it to 9 since they've basically dumped us, but if somebody can conclusively say that Waves 8 is problematic, I would definitely update it.
I honestly can't believe there isn't a Sticky at the top of the forum telling users to avoid Mountain Lion at all costs.
Aaarrrggghhhh....
Old 02-18-2015, 02:01 PM
MixerGuy MixerGuy is offline
OK my HDX-2 rig *was* incredibly stable....
Mac 10.8.4
PT 10.3.9
no VI's
then i wanted to demo a waves plugin, so I had to install all the Waves nonsense..... yes I said NO TDM.... RTAS only...
now i'm getting "Pro Tools is critically low on memory" error, and crashes... for the first time ever that error message.
Yes I repaired permissions, yes I trashed all PT prefs,
help!?!?!?
yes I have a clone of my system drive, but this sucks!
anyone getting this, due to Waves shell, etc?
Old 02-18-2015, 04:14 PM
Bill Denton Bill Denton is offline
Hopefully you guys already know about this, but make sure you don't have any applications other than Pro Tools running when you are running Pro Tools...web browsers are particularly notorious for causing problems.
And don't forget that the programs you use to measure memory and CPU usage are also using memory and CPU resources...sometimes it doesn't take much to break the camel's back...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 02-18-2015, 06:16 PM
With all that new and expensive hardware, why hamstring yourself with PT10? Just curious why no move to 11
Old 02-18-2015, 06:18 PM
many of the plugins I rely on are not AAX 64 bit (yet)
Old 02-18-2015, 07:58 PM
Ouch. Yeah, I went thru this as well. Had to purchase a few things and find replacements for others. That part does stink Now that I have made the move, its been a huge boost in performance for me. Now running big sessions and working with Melodyne and EA at the 64 buffer(used to freeze in 10 at the 1024 buffer).
Old 02-21-2015, 05:29 AM
Do those plugins have 64 bit au or vst versions installed? If so you could use Blue Cat MB7-2 or Patchwork to run the au or vst version in PT11.
Old 02-21-2015, 07:42 AM
Originally Posted by musicman691 View Post
Do those plugins have 64 bit au or vst versions installed? .
nope.
plus I'm not interested in a 'patch'
I have zero incentive to upgrade to PT 11, as I can never use faster than real time bounce (outboard hardware) and I don't use any VIs.
Old 02-21-2015, 08:55 AM
nope.
But if you stay with PT10 you're always going to be running into the ram limits of PT10. I don't see what running zero vi's has to do with going or not going to PT11.
Major CPU usage boobytrap Mark Dann Pro Tools 11 1 08-12-2014 08:01 AM
Major problems wih Pro Tools 10 and Digi003 Factory AND Mbox 3 mini DanielWiklander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-11-2013 01:05 PM
Major problems getting pro tools to work on my new mac Jabes75 Pro Tools M-Powered (Mac) 10 01-25-2011 02:58 PM
MAJOR problems with dig001, pro tools 6.1.1 on Win XP HELP! i3eezenotch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-07-2007 03:45 PM
Major Pro Tools Problems NVP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-03-2006 08:38 PM
