Re: H/W Buffer and Latency
I think I asked this before and I don't recall that you answered it - are you using the instrument version of Patchwork? There's three versions that get installed - standalone, the synth hosting version and one meant for fx. Blue Cat did the synth hosting version because people were having issues hosting vi's inside the original version. BTW I can run 256 buffer with no issues but I best not make any adjustments to a plugin while the transport is running. 128 is also okay but I reliably get audio glitches if an autosave happens with the transport running. Needless to say I've gotten good at sliding audio tracks around to compensate for the timing. |
The freeze function is great but I've noticed some VI's/plugins are really heavy on resources even with only one instance. With a older computer I try to avoid resource hungry VI's. You already probably know this but Xpand2 and Nexus2 are really cpu friendly. With a little eq'ing and multiband compression I can get better sounds out of them. Also if I do use more resource hungry VI's I try do turn off processing and effects in the VI and replace them with CPU friendly reverb, delays, etc.
It would be nice to have a new 6950x 10 core rig. Would probably be able to set and forget the hardware buffer at 64 with that one. But at over $5000 dollars it's currently out of my budget. |
I ran a little experiment this morning and with just 1 instrument track in the session and NO other tracks at all, and 1 instance of Serum, my system usage meter was pegging in the red at 99+ on several of the patches. And that's just playing them off my MIDI keyboard...nothing recorded at all. That's just way too much resource devouring! The H/W was at 256 I believe.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Thanks Jack. I'll play with it again tomorrow. You've been helpful.
I try to help when I can. And if it works for someone - more's the better. I'll be interested to see if it works for you.
#16
Funny thing is Omnisphere has no problem with lower buffer settings as AU
#17
Interesting - I guess you're using Logic then for the au?
#18
Your settings and mine are almost the same. I've tried a few tweaks, but no noticeable difference in the delay issue.
Low-Latency Input Buffer | zion | Pro Tools 11 | 109 | 09-13-2015 04:46 PM |
Latency/Buffer/External HD | craigyj | Pro Tools SE and Essential (Win) | 1 | 01-19-2011 03:15 AM |
latency on VI's vs. buffer settings | Judson | Pro Tools TDM Systems (Mac) | 7 | 12-02-2010 02:52 AM |
HW buffer size and latency | JPeters86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-07-2007 11:22 AM |
Latency/HW Buffer Question | vlad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-03-2003 10:14 AM |
