Pro Tools 7.3 bugs
OK, let me start this time.
1. Although plug-ins "EQ 2" and "Dynamics 2" were pretty useless, they are not included in upgrade to PT 7.3. So if you have a session with these plug-ins used, before installing PT7.3, copy them and after installing PT 7.3 place into the plug-in folder. By the way I am not sure they are fully compatible with 7.3 but they work just fine so far. 2. After opening a "Playback engine" and closing it, a keyboard focus (short cuts) will be disabled. You'll need to manually enable them again by pressing icon "a...z" or open/close preferences dialog and it will fix it back - how is this related???? 3 In workspace I can enable Auto-Prevew - which is very handy for audiotions. After relaunching Protools, this function will be diabled again. Thats petty.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Re: Pro Tools 7.3 bugs
I checked these against v7.3cs1.
If you install Pro Tools 7.3 over older version (Eg. 7.2) the DigiRack II will be moved to /Library/Applications Support/Digidesign/Plug-Ins (Unused)
From clean install check your CD for "Unsupported" folder.
Just wanna do music, RA. |
THANKS!
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
In preferencess>Processing>TC/E tool if you choose time shift plug-in, you cannot use any presets (though there are many) but default only.
Since this has been like that ever since TC/E functionality was added, I suspect it’s a willful omission, rather than a bug.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
In PT7.2 you could do it.....not in 7.3 cs1. So is it a bug?
I am not seeing what mgoorevich sees exactly. If I select Time Shift as the TC/E plug-in of choice, I can select presets. However, I cannot select any of the presets in the Post Format Conversions folder.
When searching files in the PT7.3 cs1 work browser, you can play them by hitting space bar.
After couple of auditions audio doesn't play, wheather you hit space bar or not. It might play if you click with a mouse on the waveform of file. But after couple of times it stops as well. After relaunching Pro Tools problem disappears just at the begining. But it comes back after several auditions. I have 2.5 G RAM which was never a problem with PT 7.2... Digi, it seems to be a bug. I tryed all the troubleshootings and rebuilt catalog again. But the problem is here.
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
Pro tools 11 Bugs | YKlein | Pro Tools 11 | 3 | 10-17-2013 08:36 AM |
Bugs in Pro Tools 9.0.3 | mkosacek | Windows | 3 | 06-30-2011 03:43 AM |
2 Minor Pro Tools 8 BUGS | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 01-06-2009 05:13 PM |
Pro Tools LE 7.0 Bugs | Larry Younkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2005 11:55 AM |
