Old 04-27-2013, 02:48 PM
RTASW RTASW is offline
Default Re: Waves Problems with delay compensation
Originally Posted by crizdee View Post
With delay comp on or off it shouldn't make any difference at all on the mix bus? in fact you can turn ADC off on the mix bus.
Chris
Hi, thanks for the info. How do i disable ADC on the master fader only?
Old 04-27-2013, 02:59 PM
crizdee's Avatar
crizdee crizdee is offline
Command+control+click on the top numbers in the delay comp window at the bottom of the track.
Whether you are using the LL version or not of L3 it shouldnt make any difference on the mix bus? providing everything in the mix is routed through the bus. but to me it sounds like something in your session is routed directly to the master channel and not routed via the mix bus maybe.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 04-27-2013, 03:01 PM
Hi folks, done some more digging around the DUC re this.
It's been going on ever since PT 7.4 apparently. Best description I saw was "things downstream effecting things upstream" ie something at the end of the chain effecting behaviour of things earlier in the chain.
To prove the point I've disabled ADC on my master Fader now (still on all the other tracks) and it works fine with whatever plugin I choose. (everything is coming through the master fader so no ADC is needed on there in any case)
Weird.
Pro Tools HD Native Thunderbolt, HD IO 8X8X8,ProTools HD 10.3.0 External 1 TB Storage, Apple Mac Mini Processor 2.6 GHz Intel Core i7 Software OS X 10.8.2
Memory 16 GB 1600 MHz DDR3
Old 04-27-2013, 03:03 PM
Chris
Hi there; catergorically everything is coming through the master fader but the drums go out of sync when i engage ADC on the master fader. See my last post.
Thanks for all your help.
Old 04-27-2013, 03:08 PM
Hi, here's a dumb question and a little off topic
How come I see 8 Host Processors available in my Playback Engine Settings?
My Mac Mini is only quad core ?? Are the other 4 representing the HD Native Thunderbolt Box?
(you'll probably fall off your chair when you read this but I was an LE user for years so it's a world of discovery for me! LOL)
  #16
Old 04-27-2013, 03:15 PM
Originally Posted by JFreak View Post
Click on your profile name on the up-right corner where it says Welcome. Then edit.
Hi, that doesn't work for me?
I can edit everything but my signature?
  #17
Old 04-27-2013, 05:43 PM
lexaudio lexaudio is offline
The other 4 are virtual cores in the processor or however it works.
I have a 12 core and I see 24 cores. I set it to 22 cores.
  #18
Old 04-28-2013, 01:51 PM
crizdee's Avatar
Near top left "User CP" control panel. Settings & options>signature. You should be able to edit everything from there!
Chris
Producer, Engineer,
www.ukmastering.com
  #19
Old 04-29-2013, 12:57 AM
Ah thanks!
Delay compensation problems Analogue Pro Tools 10 1 10-12-2012 08:18 AM
Delay Compensation Problems on AUX clancychris Pro Tools 9 0 11-09-2010 01:34 PM
Delay Compensation issue... Is it Waves? acacia Pro Tools TDM Systems (Mac) 7 03-18-2010 12:53 PM
Waves Q Clone + PT8 Delay Compensation = Issues? acacia Pro Tools TDM Systems (Mac) 5 01-23-2009 12:52 PM
Waves Tune and delay compensation Anibal Pro Tools TDM Systems (Mac) 7 09-25-2006 07:51 PM
