Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 07-07-2020, 06:08 AM
amptbuddy amptbuddy is offline
Default Why do I have to reboot S1 for EUCON to recognize controller?
I have to Reboot my S1 everyday for EUCON to recognize it. While the ipad connects without issue? What am I doing wrong? If anyone has some insight let me know that would be wonderful. Thanks!
Old 07-08-2020, 12:21 PM
peapodpost peapodpost is offline
Default Re: Why do I have to reboot S1 for EUCON to recognize controller?
Maybe it's got a bad IP and has to refresh. Where is the S1 getting DHCP from?
Old 07-08-2020, 12:58 PM
Not sure how to set DHCP. Its a simple ethernet cable direct to the tower. I did not know why it always connected when I did no have the ipad. Now its always a power up dance after a session is going.
Old 07-09-2020, 03:20 AM
OAG OAG is offline
This happens to me also every time I switch on.
Running a Dock and S1 with Amazon Fire 10 and Huawei T5.
Tablets are both fine (as long as they don't get seen as the same IP address which occasionally happens).
But both surfaces require a restart and Eucon to restart applications for them to be seen.
Frustratingly, as each surface is turned off, they appear in available surfaces.
Latest PT Ultimate on a Mojave Mac Pro 5.1.
All Avid hardware running off a dedicated router off Ethernet port 2.
Old 07-09-2020, 06:26 AM
cyborgssc cyborgssc is offline
Same behavior for me. Two Artist Mix units and a Dock. The tablet usually works right away but the hardware usually needs more than one power up to be recognized by Eucon.
Can't get pro tools to recognize my midi controller bundens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-09-2008 01:17 PM
PT 7 won't recognize midi controller Augustuspablo MIDI 1 09-07-2007 11:53 AM
PTLE wont recognize my midi controller...help! outoftune 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-20-2006 10:37 AM
ProTools doesn't recognize my controller Ragsdale MIDI 3 08-04-2002 07:48 AM
OMS doesn't recognize my midi controller anymore mister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-07-2002 03:43 PM
