Old 04-19-2020, 01:28 PM
Southsidemusic's Avatar
Default Re: Chossing an iMac 27" - Which one?
And the old ”avoid i5” is years ago. The new i5 is plenty more powerful and a higher spec i5 is what I would go for and the money saved from i9 i would put towards RAM and SSD drive and an External Thunderbolt SSD Drive for recording and that iMac would be a GREAT option for many years to come.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 04-19-2020, 02:43 PM
The_Bear The_Bear is offline
Originally Posted by Eric Seaberg View Post
The rule has always been to avoid the i5. The minimum recommendation has been an i7 which is no longer available, so the i9 should be your first choice to look at.
Thanks for your answer Eric :)
Wow, then a cheap approach isn't really an option for me.
How come i5 is something to avoid?
And I just saw at Apple's store iMac with i7. Did you mean it no longer available for Pro Tools?
And from your experience, how much difference is there between the latest iMac to, let's say, 2017 iMac? Or even 2015?
Thanks in advance:)
Old 04-19-2020, 02:47 PM
Thanks for your answer Christopher :)
What about i7? Do you think it's worth the money or maybe i5 is enough?
And which factors are for you the most important for working with Pro Tools? RAM? SSD? Processor? Which one of them has more influence on performance?
Thanks in advance :)
Old 04-19-2020, 04:49 PM
I would say all of them so if you want a solid iMac get an i5 with Big SSD drive and minimum 32 GB RAM and 64 GB if possible as those along with an i5 will be more than enough. The newer i5 processors are not the same as the older ones where everyone suggestdd going i7 so yes if you fknd an iMac i7 with lots of ram and big SSD drive (high spec) then Yes but if it is a big price difference get as high spec’d as possible and an i5 iMac and you will be set for a long time. With cash for an external Thunderbolt SSD drive for recording to aswell. My opinion of course and we have used Mac Pro’s for 15 years so I wanna think we learned something along the way what is worth putting money into and what is overkill and where to go all out to get the best option.
Best Regards
Christopher
WEBHOME
Old 04-20-2020, 02:38 AM
Thanks A LOT :)
What about the GHz for the processor? any real difference between 3.1 to 3.6?
Old 04-20-2020, 02:53 AM
Go to everymac.com and check the specs, they are all there
Old 04-20-2020, 04:03 AM
I mean from your experience. Like how much impact did you feel there was between 3.0GHz to 3.7GHz
Old 04-20-2020, 04:06 AM
As I said, GHz tells you nothing. Go there and see the geekbench score. Those you can compare
Old 04-20-2020, 04:59 AM
Originally Posted by The_Bear View Post
Thanks A LOT :)
I would say 3.1 is PLENTY and if you aren’t going to score a Hollywood movie with 800 tracks I would say no real issue with the 3.1 GHz IMHO of course
You save money and can put that towards more spec’d RAM and extra SSD drive.
Best Regards
Christopher
WEBHOME
Old 04-20-2020, 06:18 AM
K Roche's Avatar
K Roche K Roche is offline
Perhaps it would be best to back up and be a bit more specific
What is your actual current and likely future working computer load/ needs .
Music only, or music and video ?
How many tracks total normally ....
How many audio tracks....
How many virtual instrument/midi tracks et.....
And what is a realistic budget range you can comfortably spend ?
All of this specific info will give a more accurate picture for getting more targeted suggestions.
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2020.5 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Getting a lot of "Hardware buffer underflowed (-6085)" messages w/new(er) iMac Shanegrla macOS 1 12-23-2011 10:00 AM
iMac PT LE 7.3cs1 Rack 003 Error "Not Installed or Used by Another program" gcharles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-01-2010 08:24 PM
New 27" imac / "original" mbox - need some clear advice.please help !! santococo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-21-2010 10:30 AM
Can't open PT on new Imac -- "Required software extensions are missing" jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-21-2009 07:27 AM
CHOSSING THE RIGHT SCHOOL:SAE OR PROTOOLSTRAINING alion General Discussion 19 05-03-2005 12:22 PM
