Does PT 10 support raid?
My library is on a raid drive so I'm hoping PT 10 will finally support raid?
Re: Does PT 10 support raid?
From the Whats new in PT 10 Guide RAID Pro Tools 10 supports hardware-based RAID ( redundant array of independent disks) systems for opening, playing back, and recording Pro Tools sessions. However, performance is not guaranteed and is dependent on a variety of factors including network bandwidth. As with lower versions of Pro Tools, Pro Tools 10 also supports software-based RAID systems using ATTO RAID software, which makes several RAID volumes appear as a single volume to the operating system.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Please ignore the formating as it was a copy and paste hack job. I would think your sample library would not have an issue streaming from a RAID array. The only why to tell is to try it.
With RAM caching ... What do need RAID for?
except the reliability to play back or record A LOT of tracks, transfer speed for backups for example comes to mind, or even the ability to continue to work while backing up and still being able to use enough bandwidth of that disk for Pro Tools
Chris
Chris Lambrechts Applications Specialist- Live Sound |
Yes am wondering whether this will work?
http://www.promise.com/storage/raid_...tistic=pegasus Posted this question in another thread but no answers yet...appears it might... |
Someone else said the Lacie Thunderbolt (which is also RAID) was working great (I think it was Peter Moshay on Gearslutz), so I expect this would work as well.
I record all my stuff to a 4 Drive RAID0... Lightening fast. Works a charm with PT and has been for a long time... I use the software SoftRAID which is superior to disk utility but you CAN use DU... Only its very tedious....
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
PT10 is fairly drive-agnostic. That's the beauty of the new DAE - even without "Extended Disk Cache".
Does PT support Raid 1(Mirror)? | Terence520 | Pro Tools TDM Systems (Mac) | 12 | 05-06-2008 08:30 AM |
Do Pro Tools support RAID? | Hak Heng | Tips & Tricks | 8 | 11-10-2005 09:24 AM |
Does anyone know why PT does not support a RAID? | jmp | Storage Subsystems | 1 | 11-30-2003 05:02 AM |
PT does not support RAID but it still works ?? | Kristbjorg Kari | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-06-2003 09:36 AM |
Support PT LE Serial ATA RAID ??? | Sinnet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-10-2003 11:36 PM |
