RAM memory usage in PT9 / MAC OS
Hello!
I'm a bit confused here, a 32-bit system will support maximum 4 GB of ram due to address space. To use more memory a 64-bit OS is required (like Mac Osx Snow Leopard). But since Pro Tools 9 is a 32-bit application, will it be able to use more than 4 GB of RAM? And what happens with the plugins, will they be able to use more than 4 GB of RAM? Or doesn't it matter at all, will Mac Os allocate more than 4 GB RAM regardless of if the application is 32/64 bit? |
Re: RAM memory usage in PT9 / MAC OS
http://www.kwikpiks.com/files/129/protools.png
I know it's not the greatest screenshot (PT real usage isn't even visible) but that's an idea of RAM usage in Snow Leopard 32 bit. I have a first gen MacBook pro, that's PT9. My laptop has 2gb of RAM, and I have a Seagate 500gb 5400.6 hard drive inside. Due to coding, the application can only address 3gb max. You could have hundreds of gigs of RAM, but Snow Leopard can't allocate more RAM to an application than it can address.
Dual Xeon E5-2620|Asus Z9PA-D8|WD 250gb Raptor SATA-III|32GB Kingston DDR3|WD Blue 640GB SATA-II (x2)|nVidia GTX660 Ti 2GB|Antec HCG-750|NZXT Source 210 Elite Windows 8.1 Pro x64 with Media Center Pack 15" MacBook Pro 8,2|2.2GHz i7|16GB RAM|750GB drive Mac OS 10.8.5 x64 Pro Tools 11 with M-Audio ProFire 2626 on both machines |
You can run apps such as “Reaper ReWired” or Vienna “Ensemble PRO” in order to effectively access more RAM for plug-ins in A 64-bit system. Even though Pro Tools can only access RAM close to the 4GB limit, the system uses additional RAM so... If you are wondering if there is an advantage to a 64-bit system with Pro Tools and more than 4GB of RAM, the answer is yes.
Hey TOM my bud~deee
So 'beeetsss, you are saying that if you have 6GB of RAM, that Pro Tools will use it's 4, but while it cannot access the remaining 2GB; the OS and any other apps that are running can?
So it is still beneficial to have more than 4GB, even though PT can only utilize that much? Also TOM@METRO, you said Quote:
I assume 32bit Reaper also can only access 4GB? I also assume the Vienna app is a 64 bit application? Sorry for the retarded questions, I am still trying to wrap my head around this. I have tried rewiring Reaper and it did run several VI's with no problems...... but truth be told I do not know which version of Reaper I have in my studio computer.....32bit or 64 bit. I just got the app to try it, I am still running as a demo and hardly ever use it. This being the case though, I will purchase the 64 bit Reaper if it will be a cost effective solution to getting more VI's in a PT 9 session. As opposed to buying DP or Logic just for sessions with lot's of VI's/sample libraries. Right now PT seems to choke real early. I wonder how big of a deal it is for Pro Tools to become 64 bit? Is that a huge amount of rewriting the code for the application? Why don't they do it?
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
I recently asked a question like this. I think it was on the macrumors forum.
From the responses, what I understood, that even when running OSX in 32bit mode, you can benefit from more than 4gb. My understanding is that any app or OS that is 32bit can only access up to 4gb. But it doesn't have to be the same 4gb. For example if you have 6gb of ram, and the OS is using 3Gb, then PT can use the other three. Neither is passing their 4gb limit, but they don't need to share the same ram either. - Sent using Tapatalk.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
Ldogg, yes it is mucho beneficial to hav more than 4; as far as REAPER or VEPro, it of course has to be the 64bit app as well as the plugs hav to be 64bit; but, even if they aren't, that still means a different 4g or however much is available; So PT uses its 4, even if Rewired is 32 bit, it'll still use up to its own 4g as well.. If its 64bit, then it'll use as much RAM as u hav in ur rig...
edit: if the OS is 32bit, 4g is it period...
OK - let's be clear about this.
We need to break this down into the correct layers and limitations. A 32-bit OS (kernel) with PAE implemented (OS X and most flavors of Linux) should be able to see and use up to 64GB of RAM. That doesn't mean that a 32-bit application can address all 64GB. Due to memory addressing architecture limitations at the application level, a 32-bit application can only address 4GB of RAM. Example: If you have 16GB of total physical RAM installed on a Mac running Snow Leopard in 32-bit mode, Pro Tools CAN take up to 4GB (based on it's 32-bit application architecture) and you have 12GB left over for the OS and any other applications. On the example above, let's say your running Pro Tools and Rewire to extend that limit. Pro tools can allocate 4GB total, and Rewire (to another 32-bit app) can also allocate 4GB total to the second app leaving 8GB for the OS and any other applications. There are many people (including myself) who run this way at times, and it tends to work well until you run out of CPU. If you're running Snow Leopard in 64-bit mode (48-bit RAM buss/MMU), the OS can see up to 256TB (yes, TB!) of physical RAM; HOWEVER, a 32-bit app running on this 64-bit OS configuration CAN STILL ONLY ADDRESS 4GB due to its 32-bit application memory management limitation. The OS can still see 255TB+ of RAM to use for itself and other apps if you actually had 256TB of RAM installed. What about 64-bit plug-ins? My understanding is that in almost all cases, a plug-in is treated like an extension of the application and is limited to the memory address limitations of the app. I really doubt if a 32-bit app can correctly use a 64-bit plug-in anyway, but if it could, it would still be limited to the app's 32-bit addressing limitations. We could get into a discussion about running 64-bit Reaper under 64-bit Snow Leopard - Rewired to 32-bit Pro-tools (running under 32-bit OS emulation under 64-bit SL), but I haven't heard of anyone trying this. I wouldn't even hazard a guess as to whether it would work, and I would never advocate a pro facility even thinking of running this way. My gut says, "Danger! Danger, Will Robinson!" Anyone tried this? Hope this helps, NL |
I recently ran into PT memory limitations on a feature film I was mixing and reported here:
http://duc.avid.com/showthread.php?p...08#post1708808 Although Avid Tech Support didn't respond to that thread, I also asked the same question via my dealer and was in communication with somebody (unknown to me) at Avid. Basically what was said is that the current limitation of ProTools is 2.6GB of RAM memory use (exactly the amount where I ran into trouble). Beyond that things become unstable, so the only solution is to run smaller sessions or avoid using memory intensive tasks such as the Workspace. Greetings, Thierry Quote:
Thank you guys for excellent responses!
This raises some more questions though, how is memory allocated for plugins? Noiselab wrote: Quote:
The reason I ask is that large sample libraries are quite RAM heavy, it would be a severe problem if 2.6GB is the limit for all plugins to share together with ProTools. Can someone verify how memory allocation works for plugins? |
64-bit memory usage | Ben Hunt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-07-2010 03:29 PM |
memory usage? | headphono | Pro Tools M-Powered (Win) | 4 | 03-07-2008 06:03 PM |
Why does memory usage go up every second? | brianjanthony | Pro Tools TDM Systems (Mac) | 11 | 11-07-2006 09:07 AM |
Memory Usage | gg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-11-2003 01:39 AM |
memory and cpu usage | gargoyle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-13-2001 02:30 PM |
