Exporting MP3 files - 'Access violation occurred'
I'm having a problem to export my wave files as Mp3. I have a pentium Dual core, and i'm using my ilock key to convert the files. I have already convert some files, but now the system doens't allow me to convert some files saying 'access violation occurred'. Do you guys have any idea of what's wrong? Thankx in advance and take care! Fil (ATJ Records) |
Re: Exporting MP3 files - 'Access violation occurred'
Is it possible that you don't have proper access to the files? Are they being put into a compressed folder?
Can you tell me the exact workflow and when in that process you're getting the error? You should also look at the steps in the General Troubleshooting thread and see if anything there helps at all. |
Can you tell me the exact workflow and when in that process you're getting the error? You should also look at the steps in the General Troubleshooting thread and see if anything there helps at all. No... that couldn't be the problem because i do have proper access to the files. And they are not in a compressed folder. I've imported that audio files (wav. 24Bit, 44.1Hz) and i have export the files as MP3. I was able to export 8 files that way, but now i get that message... I tried the General Troubleshooting thread, but it didn't help, because aparently everything is fine with my system. i'm still seaking for help. Thanks in advance. Filipe Mac. Portugal |
Are the files you're bouncing and having problems with different in any way from the ones you're successful with? Are they saved to a different folder or drive? Are they named differently, possibly with illegal characters in the name?
I'm having the same issue and it's clearly an issue with the software. It doesn't seem to happen with any rhyme or reason and often exiting the program and restarting corrects the problem. The error message occurs after the song has played and the file conversion gets to the end of the process.
PT HD 8.0.3 Access Violation has Occurred! | shannonmills | Pro Tools TDM Systems (Mac) | 84 | 03-12-2011 12:57 PM |
access violation occurred | bigmarkus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2007 04:15 PM |
ACCESS VIOLATION OCCURRED!!! | bobbybeck2007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-25-2006 09:28 AM |
help: "Access Violation Occurred" | nostranger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-21-2004 05:12 AM |
access violation occurred? | jim jedlicka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-20-2001 07:47 AM |
