Slow starting PT since 7.4cs2
Hi all,
Since upgrading to 7.4. cs2, it takes forever to start ProTools. It gets stuck on loading certain plugins (Sony Oxford, Trim, WaveShells, Sound Toys). I'm going through the version compability grid, but it seems ok so far. Is anyone else having this problem? Best, Fredrik |
Re: Slow starting PT since 7.4cs2
Every time you make a change to the plugins folder, I.e remove or ad a plugin then the cache has to be re built everytime you boot PT, once you've loaded and settled with all your plugs it should start to boot faster. Or as you say, you might have an out of date plug causing problems! Some plugins do take longer to load up? so have you installed any new plugs at the same time as 7.4. Chris
Hi Chris,
thanks for quick response! I know about the "first time after messing with the plugins folder-start up time" But this continues after that. The only new plugin I've installed after cs2 is Melodyne studio 3.1.1.2. But I removed the Melodye-bridge from the plug-in folder, cause it isn't the latest version. (And I trashed the prefs.) But I'm gonna start taking away plugins to see if I find the guilty one... Best, Fredrik |
Slow Starting | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 01-18-2013 02:11 PM |
PT starting up really slow and crashing | Tgrokz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-16-2010 01:37 PM |
RE: Slow recording when starting a new session | nelsonmay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-02-2005 04:34 PM |
Pro tools starting slow. | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-06-2005 11:24 AM |
slow starting record problem with PTLE on XP | djsleepless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 10-05-2003 12:27 PM |
