MacBook Pro and Firewire Expresscard/34
I am using XP on a MacBook Pro via boot camp. I do not want to have to daisy chain my HD and 1814. Can someone please recommend a firewire expresscard that they have successfully used with their HD and/or firewire interface. Thanks.
OSX 10.8 Pro Tools 10 / 11 Sapphire Pro 40 Mac Pro 2.66 GHz Quad-Core Intel Xeon 10 GB 1066 MHz DDR3 |
Re: MacBook Pro and Firewire Expresscard/34
i know you can't all be daisy chaining your interface and drives. c'mon, help me out....
Alright, since I somehow seem to be the only person on this board that doesn't want to daisy chain their hd and firewire interface, I'll go ahead and answer myself so if you guys decide to upgrade, this might help.
Hey Gunnell! Try this one out: http://www.bhphotovideo.com/c/produc...Expansion.html or if you could use an extra usb 2.0 port, try this: http://www.bhphotovideo.com/c/produc...B_2_0_and.html Good Luck!
Wow, thanks Gunnell! I just ordered the one with the usb port. I'll let you know how it works out! Thanks for the help, you're awesome!
the problem is, there probably arent many people using a macbook pro with windows xp via bootcamp and running PT. calm down a bit. i have, however, successfully used the belkin ExpressCard 34 firewire/usb combo card with OSX. but see, that doesnt help you...
I'm calm. Like I said, I'm going to continue posting about this topic incase someone has the same question in the future, this thread will help.
As far as your post goes... Your info doesn't help me only because it's too late now. It definitely could have helped me days ago. XP doesn't have anything to do with it. I probably should have just left that out. The card will work on both sides. Thanks for the reply though.
I know, I know. I'm too late to help you. Well, it took M-Audio a while to get back to me. When I created a support issue about the configuration of my firewire 410 and ext HD on my macbook pro with only 1 firewire port this was the response:
[Alex Solano -- 08/21/2007 09:13:00] Actually the way you have it connected with the Hard Drive daisy chained after the FW410 is the correct configuration. Just make sure you are not using the power supply for the FW410. Hope that helps somebody. Chaining these should not be a problem...... |
Chaining will work, the only problem is that the HD and interface are now running off of the same bus. If you split them up the bus will be doing a lot less work and will run smoother and you'll be less likely to lose data or have something else horrible happen.
I understand that, though I wouldn't think that you would run into problems unless the track count was getting pretty high.
I personally have had no problems thus far, and don't feel the need to spend more $$ on a big maybe. If it ain't broke, don't fix it. J |
Makes sense. I've got a lot of tracks though. It was broke, had to fix it.
MacBook Pro, Magma ExpressCard/34 | CPettigrew | Pro Tools TDM Systems (Mac) | 20 | 10-05-2010 11:22 AM |
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter | Bloody Maker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-22-2010 09:58 AM |
MacBook Pro - ExpressCard problems - info | Richard901 | Storage Subsystems | 0 | 12-27-2008 05:30 AM |
FirmTek SATA ExpressCard/34 Adapter for MacBook? | acmost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-11-2006 07:10 PM |
Apple MacBook Pro Expresscard/34... | 1150Post | Pro Tools TDM Systems (Mac) | 2 | 01-26-2006 09:36 PM |
