#4991
Re: Best Desktops for PTLE
And I sure need all RAM I can use,things like DFH Superior ase simply impossible otherwise. Well, now I need to find out how to arrange 3 gigs in the A8N-E SLI DL. Four slots... hmm...? Or does it matter if I just put in 4G? Easier to do it properly. Sorry for going slightly OT here, good to be back.
-------------------------------------------------------------------- - i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow . - PTLE8 on a macbook. - And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24 I`m In The Band: www.ozofficial.com My guitars are in tune : http://www.truetemperament.com/site/index.php |
#4992
ok, questions questions...
Allen, I know your regular advice is to buy the best CPU so quite why I'm asking this I dont know, I guess like most of us dorm dwellers i'm trying to pinch the pennies... trying to spec a new machine based on the following: AMD Athlon 64 X2 Dual Core 4400+ Asus A8N-SLi Premium nForce4 SLi Sapphire ATI Radeon X800 GTO Ultimate 256MB Corsair 1GB DDR XMS3200XL Pro TwinX (2x512MB) CAS2 2 * Western Digital Caviar Special Edition 120GB 1200JS SATA-II 8MB Cache Mitsumi FA 404M 7in1 USB 2.0 Floppy & Media Drive - Black NEC ND4550 16x16 DVD±RW Dual Layer ReWriter (Black) Sony DDU1613 DVD-ROM (Black) Zalman CNPS7700-CU Ultra-Quiet CPU Cooler - Retail Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU AcoustiPack Pre-cut Kit For Antec Sonata II - Plus fan mounts and i'm toying with the more expensive 4800 cpu... can i expect (as on the last incarnations of the allenstein) that the better cache of the 4400 verus the 4600 will yield better performance? the 4400 saves me £220 over the 4800 and I'm expecting this machine to KICK BUTT whichever proc i choose but ya know how it is... should i blow the budget? or should i just buy the g5 dual core, i'd love to run logic too? which would rule out my using my 001... step 2 of the upgrade is of course to go to the 002r, so while i'm saving the pennies for the 002r i intend to plug the 001 into one of the PCI slots on the mobo, (i'm pretty sure that the asus webby lists the a8n sli as having 2 pci-e slots and 3 pci slots) can anyone forsee problems with this? last question, i use battery 2 which causes my current pc (an ageing p3 1 gig with 512 mb of ram) to keel over. i have to strip the kits down to keep from running out of ram, will 1 gig be enough or should i splash out and get 2 gig? help and comments greatly appreciated tim
"feed your head" |
#4993
#4994
Get what you can afford at the time as technology is changing so fast these days that by next year these dual core processors will be outdated. I'd probably go with the 4400s, and use the rest of the money to take a hot babe to the movie "Walk the Line" for a little walk down memory lane of Rock n Roll. I just bought a picture of Johnny Cash at his first photo shoot with Sun Studios and Sam Phillips in Memphis, TN. Allen |
#4995
I was thinking that the soundproofing of the case is the reason of my troubles, as the asus mb outputs most of it's heat to it's back, exactly where the soundproofing gives it a "perfect insulation". Anyhow, so are you using the stock intel cpu fan, or purchased something other? thanks, laszlo |
#4996
Hello,
I'm used to work with my MBOX (PTLE 6.4) on my laptop Latitude D600, and now I need to have also a desktop for my works, ... with a limited budget. Currently I have 2 proposal with good price : P4 630-3000 2Mb sk775 Motherboard: ASROCK 775V88, Chipset viaPT880, Fsb800, SATA or AMD ATH64 3200+ sk939 Motherboard: ASUS A8V-MX SE, Chipset viaK8M800, SATA RAID I cannot find any note in compatibility section and in this thread about the above chipsets. Did any of you have the opportunity to test them ? Thx Cheers Andrea - [email protected] |
#4997
sage like advice as ever, thanks. i'll save the money and go with the 4400 and spend the cash on the ram (unless there are any hot babes reading the forum at a loose end this evening?). reading bb_aus's comments i think i'll just stick 3 gig in the machine and get on with it. haven't researched the 2.8 gig limit to xp's ability to see ram but sounds reasonable. being a son of the early 80's (when i came of musical age rather than actually being born) i'm yet to discover the beauty of mr cash. problem might come when said hot babe prefers the wild rock n roll thing on screen but hey, deal with that if/when it comes along last thing, can you think of a sound reason to throw caution to the wind and buy the dual core mac? i'm thinking of the m9590b/a model muchos gracias amigo tim
"feed your head" |
#4998
#4999
Tx,
that's correct but I wonder if the compatibility matrix is continuosly extended by testing MBOX on last generation chipsets (i.e. chipsets from VIA). I'm afraid that in a short time I'll not be able to find any new supported hardware .. It would be good to know what's the obsolescence program for MBOX (now that MBOX2 is available) Tx Cheers Andrea |
#5000
bb aus, Thanks for the reply on the Antec Sonatta II PS. As I need the wireless card (and like the option of the other devices), I opted to return the Sonatta. So now I am looking for a higher quality and quiet PS.
I am considering the Enermax 485 W Noisetaker (just a little more juice). Also, I am looking at Antec TruePower 2.0 500 or 550 W PS. Do you (or anyone) know if this Antec line is relatively quiet? Also in consideration is the Antec NeoHe 500 W (which is quiet). The only thing on this PS is that I saw feedback that the NeoHe 430 PS (found in the new Antec P150 case) had some compatablity issues with the ASUS A8N-SLI Premium mobo that I am planning on getting. And I don't know if this incompatability extends to the whole NeoHe line. Any info. is appreciated. Thanks, DRJ |
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
