Can't Add Plugin From Mackie Universal Controller Pro
I just purchased a Mackie Universal Controller Pro with Version 4.0.3 firmware, which , I believe is the most current. I've followed the directions for inserting a plugin. I'm able to get to the correct instrument assignment, but when I turn the corresponding v-pot knob, nothing happens! The "No Insert" display just keeps flashing. Can anyone "walk" me through the process? Thanks Much!
Re: Can't Add Plugin From Mackie Universal Controller Pro
Once you have got to the "No Insert" flashing part, you need to push the "plugin assign button (F6) which will stop the flashing and allow you to turn the channels v-pot to select the plugin you want and push plugin assign once more and there you have it! Push the v-pot again and you will be able to edit the plugin parameters.
1, plugin button from assignment 2, hold down the insert key and choose the channel you want the plugin on. 3, push the plugin assignment button (F6) 4, turn the v-pot to select the plugin you want 5, push the plugin assignment button again to add it to the channel. 6, once selected, push the v-pot again and you can edit the plugins parameters I hope this helps!
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Mackie Control Universal with PT | GreatCthulhu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-30-2008 04:24 AM |
Command 8 or Mackie Universal Controller?? | rcd | ProControl, Control|24, Command|8 | 3 | 12-10-2007 09:08 AM |
ANYONE! Mackie Universal Pro!! YES OR NO!! | BTGR&P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-07-2007 01:56 PM |
Mackie Universal controller setup documentation? | seattleguitarman | MIDI | 0 | 12-03-2006 11:29 AM |
Anyone using the Mackie C4 plugin controller? | PTLExp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-19-2006 12:14 PM |
