No "Select Next Track" key command for mix window?
I've looked high and low but I cannot find a key command for "Select Next Track" in the mix window in Pro Tools 11, a la "p" and ";" in the edit window.
Am I missing something obvious here? Does this need to be added to the "extremely obvious stuff" list of things PT is lacking, LIKE A PHASE BUTTON ON EVERY TRACK? cha
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
Re: No "Select Next Track" key command for mix window?
For what specific purpose do you need to select the next track in the Mix Window ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
In this case, I was doing the repetitive task of exporting track presets from my template, about 50 of them. So exporting a single track at a time. (I created a key command "option + x" for "export selected tracks" to make things go even faster.)
I like to do as much from the keyboard as possible. I ended up doing it from the edit window with "p" and ";" but I can think of plenty of other times I've wanted to be able to do this, especially to use "shift" and "r", "m", "i" or "s". And now with PT 11 I can see wanting to use it to quickly bypass plugins or aux sends on multiple tracks. Or even just to quickly select a bunch of tracks for some kind of batch processing like assigning them all to the same input or output or adding the same plugin or send, or making tracks active or inactive or hiding them, all from the mix window, in which I happen to be working at the time.
Thanks for explaining your advanced workflows. Makes sense to me now.
Should be a shortcut, because scroll-to-track is too lavish. Sadly, there are even a lot of exisiting menus without a shortcut (cut/copy/paste-special , edit-fades-delete , manual write-automation to selection ,...) but a lot of unused shortcut possibilities.
What is the key command for "link track and edit selection"? | jkuehlin | Pro Tools 10 | 5 | 10-21-2023 05:07 AM |
EuCon command for old Command8 "Plug In" window button? | myhrik | Pro Tools TDM Systems (Mac) | 6 | 06-21-2013 03:48 AM |
unable to select "find all candidates" in relinking window... | duckandcover | Post - Surround - Video | 3 | 09-14-2012 01:19 PM |
Is there a way to unlink "Track Show/Hide" between mix and edit window? | Tobias Eichelberg | Pro Tools TDM Systems (Mac) | 13 | 09-25-2010 01:23 AM |
editpack track select gives "No Valid Tracks"??? | jmattchan | ProControl, Control|24, Command|8 | 1 | 05-27-2009 05:44 AM |
