Hi!
Some info on my setup: -I have a fast track solo. I run audio out of the 1/4 jack and split it to two Rokit 5 studio monitors. See below for full report. The issue I'm experiencing: My audio cuts out and will not come back unless I go to sound settings, disable the fast track solo, and enable it again. If I try to do anything audio related (play a song in itunes, watch a youtube video, watch netflix, etc.) nothing happens - songs won't play, youtube won't buffer or play, netflix gives an error and dies. As soon as I disable the fast track solo the song or video or whatever it is will start playing and when I re-enable the fast track solo the audio comes back in. It seems like the audio never cuts out when there is currently audio playing - it happens if there is no audio playing and then I put something on. It doesn't happen consistently every time though - it just occasionally cuts out. For awhile I thought it was a USB issue - I've configured every USB port on my computer to maintain power and never cut power. I've also tried running the fast track solo through an externally powered USB hub. Does anyone have any suggestions on what could cause an issue like this? Let me know if there is more information I can provide. SiSoftware Sandra ID Host Name : Workgroup : WORKGROUP Computer Model : HP Pavilion AZ221AAR-ABA HPE-170t 103C_53316J Serial Number : Chassis : HP Desktop Mainboard : MSI IONA BIOS : AMI (OEM) 5.11 01/28/2010 Total Memory : 8GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz (4C 8T 2.93GHz/3.46GHz, 2.4GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1156 Chipset Memory Controller : HP Core (Clarksfield/Lynnfield) DMI 2x 2.4GHz (4.79GHz) Memory Controller : Intel Core Desktop (Lynnfield) UnCore 2x 2.4GHz (4.79GHz), 2x 4GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Kingston HP497157-C01-ELDW 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston HP497157-C01-ELDW 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston HP497157-C01-ELDW 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston HP497157-C01-ELDW 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : BNQ BenQ GL2760 (1920x1080, 27.2") Monitor/Panel : LG TV (1920x1080, 91.0") Monitor/Panel : ACR Acer S201HL (1600x1200, 19.9") Video Adapter : NVIDIA GeForce GTX 970 (13CU 1664SP SM4.1 1.08GHz/1.42GHz, 1.8MB L2, 4GB 7GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 970 (13CU 1664SP SM4.1 1.08GHz/1.42GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 970 (13CU 1664SP SM4.1 1.08GHz/1.42GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit, PCIe 2.00 x16) Graphics Processor CUDA GP Processor : NVIDIA GeForce GTX 970 (1664SP 13C 1.08GHz/1.42GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit) OpenCL GP Processor : NVIDIA GeForce GTX 970 (1664SP 13C 1.08GHz/1.42GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit) Compute Shader Processor : NVIDIA GeForce GTX 970 (1664SP 13C 1.08GHz/1.42GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit) Storage Devices WDC WD7500AZEX-00RKKA0 (750.2GB, SATA300/600, 3.5", 7200rpm) : 699GB (G:) (H:) Samsung SSD 840 EVO 250GB (250GB, SATA300/600, SSD, SED) : 233GB (C:) (I:) Generic- SD/MMC (USB2) : N/A (J:) Generic- Compact Flash (USB2) : N/A (K:) Generic- SM/xD-Picture (USB2) : N/A (L:) Generic- MS/MS-Pro (USB2) : N/A (N:) WDC WD20EARX-00PASB0 (2TB, USB2/SATA150/600, 3.5") : 2TB (M:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (F:) Logical Storage Devices ZZZZZZZZZZZZwtf is this (G:) : 100MB (NTFS, 4kB) @ WDC WD7500AZEX-00RKKA0 (750.2GB, SATA300/600, 3.5", 7200rpm) Data (I:) : 100MB (NTFS, 4kB) @ Samsung SSD 840 EVO 250GB (250GB, SATA300/600, SSD, SED) Ext Swag (M:) : 2TB (NTFS, 4kB) @ WDC WD20EARX-00PASB0 (2TB, USB2/SATA150/600, 3.5") Stuff (H:) : 699GB (NTFS, 4kB) @ WDC WD7500AZEX-00RKKA0 (750.2GB, SATA300/600, 3.5", 7200rpm) SSD Swag (C:) : 233GB (NTFS, 4kB) @ Samsung SSD 840 EVO 250GB (250GB, SATA300/600, SSD, SED) Removable Drive (J:) : N/A @ Generic- SD/MMC (USB2) Removable Drive (K:) : N/A @ Generic- Compact Flash (USB2) Removable Drive (L:) : N/A @ Generic- SM/xD-Picture (USB2) Removable Drive (N:) : N/A @ Generic- MS/MS-Pro (USB2) Optical Drive (F:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : HP H57 LPC Interface Controller Audio Device : HP P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semi 888 High Definition Audio Audio Device : ZOTAC International (MCO) GM204 High Definition Audio Controller Audio Codec : nVidia nForce4 Intel Edition CPU to PCI Bridge Disk Controller : HP P55/PM55/3400 6 port SATA AHCI Controller USB Controller 1 : HP P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : HP P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : HP VT6315 Series Firewire Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Send to Kindle (4000x4000, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 6700 (600x600, Colour) Printer : Fax - HP Officejet 6700 (200x200, Colour) Fax : Microsoft Shared Fax Driver (200x200) Scanners and Cameras Scanner : Hewlett-Packard HP Officejet 6700 (NET) (Scanner, USB) Peripherals Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps) Network Adapter : VMware Virtual Ethernet Adapter for VMnet1 (Ethernet, 100Mbps) Network Adapter : VMware Virtual Ethernet Adapter for VMnet8 (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Home Media Center 6.01.7601 Service Pack 1 Platform Compliance : x64 |
What happens if you disable your other audio interfaces in Windows so that the Fast-track is the only interface? I would also make sure Windows is set to the same sample rate that you normally use your Fast-track at.
No luck with either of those unfortunately
Audio Cutting out with MBox Pro and PT 10 | triplizard | macOS | 16 | 03-02-2014 03:24 AM |
Pro Tools is cutting my audio. | naveia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-19-2006 03:45 PM |
Audio cutting out randomly | Popsicle Bob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-21-2006 11:11 AM |
PT 7/OSX 10.4.3 audio cutting in and out | The Missile Silo | Pro Tools TDM Systems (Mac) | 2 | 02-03-2006 04:51 AM |
Audio cutting out at the end of .wma imports | Steel City | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-14-2004 08:34 PM |
