Converting back to 7.4?
I am currently running Pro Tools 8.0.4
I have piano and bass tracks recorded. I am going to a studio to record drums that is running Pro Tools 7.4 How do I convert my sessions so they are compatible? Also, the piano is Midi Grand; will that plug in work on 7.4? |
Re: Converting back to 7.4?
Print your tracks starting from zero and start a new session. Then bring your new session (created with PT7.4) and open it in PT8 and import your old stuff back.
I don't remember 100% but I believe Mini Grand was introduced in PT8 so you need to at least print that. You only have two tracks, why not print both? Saves you a lot of time on the other studio. If both tracks start from zero, it is easy to create a new session and add that audio to a two new tracks.
I'm sorry but what do you mean by "print your tracks starting from zero"?
Select timeline starting from zero ending shortly after the last note (if you want to include reverb tail for example), then hit solo on that Mini Grand instrument track, then bounce it out and there you have your instrument track printed out as WAV.
Thank you; where should I bounce it to?
The same Audio Files folder that is used for the other content in your session (everything in the regions list).
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
I'm really confused:
I looked it up online and it says to choose "Save Copy In" when a session is open and from the drop down menu I should be able to select 7.4 However my drop down menu lists only: Latest PT 5.1-6.9 session PT 5.0 session PT 4 24 bit session PT 4 16 bit session PT 3.2 session Does anyone have ideas about this? Thank you. |
7.x-9.x are the same session format but audio file waveform overviews changed form 8 bit to 16 bit at PT 8
Should I back back all files from my internal hd to my OWC external firewire800 hd? | moya83 | macOS | 1 | 11-12-2012 06:36 AM |
PT Converting Mono to Stereo and Back Problems | Wavelabs | Pro Tools M-Powered (Win) | 2 | 01-29-2010 07:59 PM |
converting wav to aif and back changes sound - ? | Mark Dann | Pro Tools TDM Systems (Mac) | 11 | 10-16-2006 08:52 AM |
Digital feed back on play back after Bounce | drew88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-12-2005 01:18 PM |
Converting WAV to MP3, then MP3 back to WAV...Will the quality suffer too much? | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-09-2002 12:51 AM |
