#21
Re: Striped HDs for Sample drive
Awesome... thanks for all the info.
next time i get into the studio I'll try all of this. But can i move over MiniGrand and Xpand? or is that not needed? or possible?
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
#22
Possible yes; Needed no..(Just my opinion tho) Even on my Core2duo I left Xpand & Min Grand as 'em were (But again, this is just me)
#23
Large blocks help when files are large; generally that only helps if you are writing monolithic sample files (XPand2 & Mini-Grand for example.) Things like Kontakt (& Structure & BFD) would not be helped (unless you've stored the samples as monolithic files which isn't the default for most libraries -- usually all the individual samples are stored as separate waves.) Large blocks can be a detriment to a drive often (wasted space from unfilled blocks, access time increases due to the need to read in each larger block before doing any operations.) The default setting is there because, in general, it's the optimal size for most uses. |
Sample drive and PT session drive disappear | stevedresser83 | Windows | 12 | 05-10-2011 03:23 PM |
Audio and Sample From The SAME DRIVE Can Be Done With An SSD. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 06-13-2010 11:21 AM |
Striped vs Mirrored Drives? | guitar486 | General Discussion | 5 | 06-20-2008 06:11 AM |
PT6 and Xerver RAID - striped storage at all? | houser | Pro Tools TDM Systems (Mac) | 6 | 07-13-2003 12:17 AM |
Anyone ever install a drive that is RAID striped? | fumanii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-04-2003 11:14 AM |
