Repeated Error AAE-9171
Hello and thank you for taking a moment to read this thread. I'm having some trouble in PT12 with AAE -9171 errors. The system I'm using is pretty spec'd out and the sessions I'm running are nothing crazy (-60tracks) so I'm a little confused about why this keeps happening. It's interrupting my work. I did a lot of searching around yesterday before joining the forums to post this. I hope that this isn't redundant. Some details:
WiFi As soon as I open the session, PT starts reporting some outrageous CPU usage. This screenshot was taken while paused: I'm new to the HDx Core system. Should I expect the load to be more evenly distributed? Does 99% as seen below have anything to do with why I would keep getting interrupted with these errors? (also while paused) The following screenshot shows a general overview, including the error dialog in question: The session open is not very heavy with plug-ins. I'm doing most of my processing with outboard. I wondered if this was perhaps a Sync issue with the Sync HD? It appears to be locked and working as expected. Any help would be appreciated. Thanks. |
Re: Repeated Error AAE-9171
I will add that I've tried disabling WiFi. I've tried disabling all inserts in the project. Any extraneous tracks have been hidden and made inactive. I should have included this in my original post but I thought it would appear as my signature because I updated my profile as suggested. Regardless, here is a detailed description of the system:
2012 Mac Pro Processor: 2x2.4 GHz 6-Core Intel Xeon Memory: 40GB 1333 MHz DDR3 ECC Graphics: ATI Radeon HD 5770 1024 MB Pro Tools 12.6 HD w/ 2 PCIe HDx Core Cards Avid Sync HD linked to HDx Core card with serial cable Burl B80 Mothership & B52 Converters All of the above sync'd to an AMS Neve Genesys 72 input console using linear time code. I am using on-board (Encore 6) automation, not the HUI DAW control. |
I'l give this a shot but others will know more. I would not be concerned about the 99% on HDX. It's usually the native processing that causes trouble. Typically the HDX processors fill up one by one as you have in you pic.
I do know that many folks have reported issues with El Capitan so I'm guessing that may be part of you issue. Sometimes trashing your preferences clears stuff like this up. I have gotten that error when I rush things like clicking on a VI window right after it opens or pressing play while waiting for EA files to render. Hopefully others can help more. Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Thanks, Carl. Downgrading the OS isn't really an option right now, I think. I have some administrative control over the setup but project timelines and personal schedule restrict my ability to do that sort of deep re-organization. I hope that a solution will present itself. The problem is persistent and troubling, considering the obvious expense that's been undertaken to avoid a scenario like this.
I'm a PC guy, not Apple, but the 17,000 idle wake ups gets my attention. Is there something that is turning itself off to save energy and that has to be constantly re-enabled?
What buffer?
Buffer is currently set to 2048 samples, the maximum available.
Energy Save features have been disabled in System Preferences. |
12.5 bug report AAE error -9171 | solarduan | Pro Tools 12 | 10 | 11-21-2016 09:29 AM |
9171 error with HDX but not with Aggregate I/O | pklein | Pro Tools 12 | 0 | 07-15-2016 07:57 PM |
PT 11.2 with HDX 9171 error | David Sandwisch | Windows | 5 | 12-02-2014 07:24 PM |
Constant error 9171 & 9129 Pro Tools 10.3.2 | jsdetoro | macOS | 14 | 12-18-2012 07:57 PM |
Repeated Asio device has changed error | hgent | Windows | 10 | 12-30-2011 01:47 PM |
