Re: Please help rating older I7-3770 processor's "power" for PT12
Don't take it as a given. You can always create a new session @48k and import audio & possibly session data. Then you can finally convert your mixes/stems to 96k if required.
If you cannot fully influence the amount of tracks, the sample rate etc. that are given to you, you need to be prepared for the worst and hopefully still have some headroom left. Quote:
You're only mixing/editing (right?) and it can be re-enabled for offline bouncing of a project (or does not even influence it, I don't know). |
That computer isn't that old. This sounds like problems with one or two plug-ins. I would disable tracks and plug-ins until I could identify the culprit and then freeze every track it's on up to the plug after it.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
i7-3770 released Q2-of 2012
https://ark.intel.com/products/famil...-i7-Processors In computing terms that CPU is ancient...... Moore's Law and all. I didn't say it was useless, but it isn't new or recent by any stretch of the imagination.
Your graphic adapter could also be a bottleneck, and you can upgrade to a pretty powerful card for $200-300 these days. If you want to look to a newer system, I would recommend the ASUS X99-E WS/USB3.1. You can put the 5960X 8 core or 6950X 10 core CPU on it. Also you will be using DDR 4 ram, and you can use the Thunderbolt 3 add-in card. Has tons of slots for upgrade. All works well with Windows 7. FWIW, I'm running the 5960X on that motherboard, overclocked to 4.4GHz, and using only air cooling. Heat is not a problem even at 100% CPU. Be aware if you move into Skylake or Kaby Lake you will get caught up in the "have to use Windows 10" game, and for reasons of stability and security, you may not want to use Windows 10. Last edited by TAMBOR; 04-20-2017 at 10:08 AM. Reason: correct spelling |
For all of the badmouthing, I've found windows 10 to be far more stable than windows 7 ever was and I'm not alone.
I agree about the RAM but otherwise that computer shouldn't be a problem.
yes i have found that I reallllly like win10. Very Stable and very happy.
By definition, an OS that does not allow you to fully control the application of updates/patches is not "stable". You will always be at the mercy of someone else's decisions, someone with whom you can't communicate or hold accountable. (Hmmm... sounds kind of like AVID, but that would be a different thread.) |
I am seeing more and more problems arising with Win 7 users. I think testing for most devs with 7 has pretty well stopped. http://www.pro-tools-pc.com/windows-...ng-phone-home/ http://www.pro-tools-pc.com/data-col...-phone-home-2/
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
The "modern" version of that same processor is the 7700. Typical upgrades are about 7-10% more power per generation. Benchmarking tests between the 2 processors shows that to be pretty well true between them. 30-40% improvement in the 7700.
Wrong "auto-rating" of clips during loop recording | joachim | Pro Tools 11 | 5 | 02-10-2015 11:58 PM |
wrong "Auto"-Rating of Clips, loop rec 10.3.7 HD Mac/Win | joachim | Pro Tools 10 | 14 | 05-23-2014 09:45 PM |
Power harness issue and "Rev "g" series 002R | mcgwd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-19-2010 10:10 AM |
do i have to buy "european" version of digi002, or use "american" with power adaptor? | stoka | General Discussion | 3 | 10-04-2002 05:28 AM |
