Old 11-14-2018, 08:09 AM
eaglecanyon1952 eaglecanyon1952 is offline
Default Optimazation of ProTools 12.7.0
I'm in the middle of doing a new system Optimization and have a question on the part on Hyper Threading or Turbo Boost.
In my new Dell 8930 bios there is no line for Turbo Boost of Hyper Treading but there is a setting for Intel Speedstep (enable, Disable) is that what use to be Hyper Threading or Turboboost. Anyone here with a new Dell XPS 8930 I7 8086 cpu (or the 8700) that can confirm if this is what I need to disable for the "Turboboost".. .I talked with Dell today... they have no idea
Thanks in advance for the help. If there is other things in these new system bios I need to address I'd appreciate that info as well.
Thanks
Dave
Old 11-14-2018, 12:34 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Optimazation of ProTools 12.7.0
http://avid.force.com/pkb/articles/e...411&popup=true
Should have what you need. Hyperthreading is not in this list but there is a forum thread with the how to-google "turning off hyperthreading duc.avid"
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 11-15-2018, 04:27 AM
64GTboy, Thank you for your response, the link you sent to me is the same set of instructions that I have been using, On that set of instructions there is no mention of "SpeedStart" by Intel, I do understand Hyper-threading and I do understand TurboBoost, Neither of those options are in the New DELL XPS 8930 bios choices. In the top of the List in the Bios there is a line "SpeedStart" which is enabled with a choice of disabling it. I am thinking that may be what they refer to as Turbo Boost but, before I go and change it I posted my question to see if anyone has run across the same issue. It looks like Intel has been using that terminology for a few years.
So, Again, Is there anyone who has one of the newer Dell systems that show this feature in the Bios and did you disable it?
Dave
Old 11-15-2018, 12:50 PM
junkgear's Avatar
junkgear junkgear is offline
Do you mean Intel Rapid Start?
Rapid Start technology helps a computer sleep/resume faster and would really have no affect on Pro Tools. So, you can leave that enabled.
Will
System Details
Old 11-16-2018, 04:44 AM
Nope, it isn't rapid start, I"ve uploaded a screen shot of my Bios on the Advanced Page, as you can see it is Intel SpeedStep I"ve disabled it for now as it is the only thing I've been able to see when I google it.. but from 2010 there is a mention of it in an avid document but not much about it. When I Disabled it the performance of the system took a 12% hit according to Passmark Benchmark CPU Mark... but in ProTools the system performance in a project I've been using as a test really didn't make any difference
Old 11-16-2018, 04:47 AM
I guess what I am really trying to figure out is how to maximize performance and minimize latency... Right now with a fairly full 20+ track project at 48K with quite a few plug ins I"m at a latency of 64 and really stable.. Folks talk about latency and of course zero is better but others I walk with it seems like the norm in a system similar to mine is 64 so perhaps I'm chasing something that I should not really worry about ..
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
power management..optimazation mikeyman Pro Tools 10 3 01-14-2014 12:34 PM
I have ProTools 8, But Avid is only giving me ProTools 7.x Authorization Codes jpsaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-14-2012 08:34 PM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
