Old 03-15-2019, 02:37 PM
Sean Bombz Sean Bombz is offline
Default Channel 4 and 14 go to sleep!
So I'm having a weird issue where channel 4 and 14 go to sleep about 10 seconds into a session.
The first time it happened was in logic pro x 10.4.4 but not in pro tools.
Now it's happening in both.
I ran vegas mode and the both faders worked. Any help would be appreciated. Thanks!
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Old 03-15-2019, 05:30 PM
mattrixx mattrixx is offline
Default Re: Channel 4 and 14 go to sleep!
I hda Fader 6 go to sleep on me yesterday (in Logic Pro X 10.4.4),, Simply power cycling the S3 fixed it..
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 03-16-2019, 11:46 AM
Power cycling worked for me the first time it happened with Logic Pro but not this time. I put s3 into utility mode and all faders worked on Group, sine, triangle etc. When I opened up session 14 worked again but not 4.
Sean Bombz
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Old 03-28-2019, 03:28 PM
So just in case anyone else has this issue with Logic 10.4.4. I had the problem of faders sleeping follow me from logic to pro tools. I had to open logic. Shut down s3 while eucon app was running. BUT I had 2 faders that were sleeping so I had to shut down twice for it to fix both sleepers. THEN when I opened up pro tools no more sleeping faders.
Sean Bombz
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Left channel click track bleeding into right channel lokimojo macOS 5 08-29-2014 11:44 PM
Strange CoreAudio issue - right channel information getting into left channel -JK- Pro Tools 9 5 01-10-2011 08:42 AM
Multi-channel plugin default 'channel view'? Floydio Tips & Tricks 1 11-26-2010 10:47 AM
Selecting a Channel on Icon does not select channel in ProTools teacherman ICON & C|24 2 06-07-2010 11:59 AM
G3 - Sleep!?! What gives? Rob Raden Pro Tools TDM Systems (Mac) 6 08-10-2000 12:44 AM
