Waveform View And Volume
Hello!
I just saw, that HD seems to have a feature where, in the Edit window, the size of the waveform increases when you push the volume up. Do I have to switch something on in LE for that to happen, or, do we not have that feature?
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Re: Waveform View And Volume
Sounds like you are referring to clip gain which is part of the standard Pro Tools.
Well it increases and decreases if using Clip Gain in both HD and non HD (there hasn't been an LE version for years).
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
No. The presenter didn't use clip-gain, he moved the fader on the track header, on the edit page, affecting the entire track. I believe clip-gain needs you to separate the clip you want to affect.
"non HD", "LE", same thing; still not the real thing; semantics.
If so please provide the link.
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
No that IS clip gain which is called "trim" and is actually controlled by the "Trim" plug in which comes standard with all the pay versions of PT from version 11 or 12. It was not available with any LE or First though you may be able to purchase it for use in First from the PT App store but I'm not positive.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Sorry, I can't. It's from "ThinkSpace"; copyright and all that. Anyone here studying there?
I'll shoot a question off to them and see.
It has to be Clip Gain. That’s the only function in Pro Tools that will alter the waveform height when changing the level.
Pushing the fader up or down in either the Edit or Mix window won’t do that. Sent from my iPhone using Tapatalk |
The fader pop up of Clip Gain could easily be mistaken for the channel fader if track size is small enough. |
Volume automation to be visible while in waveform view? | Dolly | Pro Tools TDM Systems (Mac) | 2 | 03-21-2011 06:40 AM |
Waveform/Volume View Toggle Customizable? | Max H. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-06-2011 08:35 AM |
Toggle Track View not working (waveform/volume/etc) | Imgoinmad | Pro Tools 9 | 4 | 11-24-2010 04:35 PM |
Toggle volume waveform view | Hanslemonverm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-23-2010 11:40 PM |
Waveform --> Volume view ??? | Brian Kingman | General Discussion | 2 | 11-12-2000 04:46 AM |
