Cracks on PT9.0.3 with Digi003 and MacOS10.6.7
Hello,
Too many digital cracks under the normal recording mode AND the QuickPunch Mode... Anyone experiencing this under Mac? I ve seen a lot of same problems with our friends under PC ? What Avid is doing now? Please do something quikly for the Digi series... I know you want to clear them... But not like that... At least with a proper final driver... I am still using it with my client and if I ve got to many cracks I will loose client... And I will not be able to save money to buy something new from you... Do you understand... Unless I go somewhere else... lol... Time is money for both of us... Cheers
Jean @ http://www.icisound.com |
Re: Cracks on PT9.0.3 with Digi003 and MacOS10.6.7
Try using a different drive... external drive that is PT compatible. Make sure if you have upgraded the PT version and that you upgrade all your plug-ins as well. Start with a new session... set it up for your computer (Buffers, inputs, outputs, playback engine, etc, etc, etc) and then save it as a template in the In/Out library, as well as the actual session file. Once you get to the "no click" point use the template for everything you need and it shouldn't hiccup anymore.
Most of what I have read/seen about cracks and pops had to do with Hard Drive or PT settings. |
Cracks and Pops using 96k | tim carter | Pro Tools TDM Systems (Mac) | 3 | 06-23-2011 07:59 PM |
9.0.3 is here but the cracks and pops too ? | jeam25 | Windows | 22 | 06-18-2011 09:19 AM |
cracks and pops on new pc with fw 410 | tweepuntnul | Pro Tools M-Powered (Win) | 4 | 10-13-2008 11:36 AM |
old g4/001/macos10.3.9 maor problem..... | kobeaki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-10-2006 06:03 PM |
Bombfactory cracks me up! LOL | Jayman#9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-31-2003 12:57 PM |
